Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 06-30-2013, 05:38 PM   #1
stros
Drives: 2010 Camaro 2SS/RS
Fixing up a 78 Trans Am - newbie question
Hi - thinking about picking up a local 78 Trans Am that's for sale. It needs a new headliner and carburetor (Olds 403 engine). Otherwise it looks pretty solid.
Any idea what this would approximately cost me in parts & labor in the SF Bay Area?
Thanks
2010 Silver SS/RS L99. Pedders Radius Rod & Subframe Inserts, Pedders Sway bars, Pedders Lowering Coils, Pedders Rear Alignment Kit. Solo Mach XL w/J Pipes Catback exhaust
stros is offline   Reply With Quote
Old 06-30-2013, 08:38 PM   #2
45TH RS
45TH RS's Avatar
Drives: 2012 45TH 2LT RS
I just purchased new headliner material for my 80' Camaro from NPD for $67.00 (OEM Dark Blue - Perforated Material w/ Foam Backing). My original T-Top headliner is in mint condition, but is starting to sag by the rear window on passenger side. The foam backing pulled away from the adhesive do to age. So, I decided to replace it with new material, as I show the car.
45TH RS is offline   Reply With Quote
Old 06-30-2013, 09:27 PM   #3
shank0668
shank0668's Avatar
Drives: '00 WS6/'06 LJ/'76 Trans Am
Send a message via AIM to shank0668
Extremely safe bet would be $1000. Just depends on the carb, but really should be do-able for $500. Check the trunk, quarters, rockers, and rear frame rails for rust. As well as the floors.
Good luck!
Old 07-01-2013, 10:38 AM   #4
stros
Thanks guys for the tips & suggestions. Appreciate it.
