BORLA
Old 06-30-2013, 07:08 PM   #1
infernostripes!
Drives: 2010 1ssrs
Paddle shifting feels more responsive than in D and S?
Does anyone know why my car feels a lot more responsive when I'm shifting behind the wheel than when it is in D and S? It's tuned just to throw that out there. & I'm sure there's a difference in response, I've been driving my car for 4 years and I can tell
Thanks for your input
infernostripes! is offline   Reply With Quote
Old 06-30-2013, 07:11 PM   #2
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
There should be no difference... the tune affects D gears 1 thru 6... and S gears 1 thru 6 independently but not tap shift. Your tune is probably set up a bit firmer in S so what you're experiencing is the difference between D and tap shift mode, plus you are able to hold your shift to higher RPMs using tap shift.
Old 06-30-2013, 08:09 PM   #3
infernostripes!
Drives: 2010 1ssrs
I was thinking that there shouldnt be a difference but the car is much more jerky in tap shift than in S
Old 06-30-2013, 09:47 PM   #4
mlee
www.CamaroFans.com
mlee's Avatar
Then it's the shift at higher RPM than normal. It's a good thing and you have a great tuner.. Enjoy..
Old 06-30-2013, 09:56 PM   #5
infernostripes!
Drives: 2010 1ssrs
Is there anyway that I could find out at what rpm to shift at???
Old 06-30-2013, 10:01 PM   #6
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
If you have a dyno sheet that'll tell ya
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 06-30-2013, 10:43 PM   #7
mlee
www.CamaroFans.com
mlee's Avatar
Using paddles it's all up to you. Just run your car in Sport mode without paddles. Paddle shifting is totally worthless for anything performance wise. They are only for fun.
Old 06-30-2013, 11:17 PM   #8
2SSnTEX
2011 2SS L99 Vert.
2SSnTEX's Avatar
Drives: 2SS
You'll know when to shift when it starts banging out.
Using the paddles, when I have the rpms up around 4ish it def jerks when u play with the gas. can't do that in D or S, when u let off gas alil bit it shifts up and drops rpms stopping the jerkiness.
2SSnTEX is offline   Reply With Quote
Old 06-30-2013, 11:18 PM   #9
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
The tune effects tap shift as well.
There are pressure, shift timing, and converter lockup settings for drive, sport and tap mode.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 06-30-2013, 11:19 PM   #10
SPCBA
Drives: pleather and Chiclets
i dont know how you drive car, where you drive it, or anything about your car.
i disagree. having more control of car is a performance increase in my opinion.
ya 1/4 mile its prob best to let car shift anything else i would say a human brain
SPCBA is offline   Reply With Quote
Old 07-01-2013, 12:07 AM   #11
mlee
www.CamaroFans.com
mlee's Avatar
I stand corrected... I had never seen tables associated w/ manual mode.
Yes, I'm talking about both drag and road track. I guess if you're holding rpms in the power band around town that would be considered performance, but if I'm going WOT I'm certainly not going to rely on tap shift.
Old 07-01-2013, 12:21 AM   #12
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I was using the paddle shifters for a few roll races, came in handy. If I used the paddle shifters it's usually to hold out a gear on the highway so I can scare people.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-01-2013, 01:30 AM   #13
SPCBA
having the car at the right and predictable spot in the powerband coming out of turns is pretty important in road courses. using some downshifts for braking also can be considered performance orientated.
with all that said, i am killing my stock ss trans. will have the one out of zl1 and ctsv with customized gearing before summers out.
Old 07-01-2013, 01:38 AM   #14
infernostripes!
Drives: 2010 1ssrs
I have a dyno sheet!
