Old 07-01-2013, 02:35 PM   #15
trw427ss @ Futral
trw427ss @ Futral's Avatar
Drives: 2013 2SS/RS L99
I run the Stainless Power and the quality and fit are Great! And as you can see from my sig they perform very well also!
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss @ Futral is offline   Reply With Quote
Old 07-01-2013, 03:18 PM   #16
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
Originally Posted by Jason 98 TA View Post
Or just buy the tsp headers. They're the best great price, thicker material, magma flow cats, off road pipes look like cats, polished stainless, available in 1 7/8" or 2", etc...
Are the 2" still on back order?
RaiderSS is offline   Reply With Quote
Old 07-01-2013, 03:21 PM   #17
Camper
Banned
Drives: 10' 2SS LS3 M6
I must say I saw the rotofab piece this last week and what a work of art. impressed me over the CAI tbh
Camper is offline   Reply With Quote
Old 07-01-2013, 03:39 PM   #18
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Originally Posted by ABM Camaro View Post
What's a better header. TSP or stainless power headers?
I read kooks are great and wont throw a code for the cats, but they are out of my budget
Both good options. I'd say they are about equal. TSP a tad cheaper plus they don't charge any extra for 2inch vs 1 7/8.
Camarojt is offline   Reply With Quote
Old 07-01-2013, 09:30 PM   #19
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Just search this section for the brands you are considering. There are literally HUNDREDS of threads on headers and CAI's.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-01-2013, 09:47 PM   #20
wally mayfield
wally mayfield's Avatar
Drives: 2013 2SS 6M
for giggles:
"Smaller diameter pipes flow less volume than larger ones, but the exhaust in the smaller pipe flows faster. Until you reach the RPM where the sheer volume of exhaust gases require bigger primary tube diameters, smaller tubes will scavenge the cylinders more efficiently. If you're using the engine in the 1,500 to 3,500 RPM range, which is typical for a street-driven vehicle, you definitely want 1-1/2" to 1-5/8" primary tubes for any small block and 1-3/4" to 1-7/8" for a big block engine. Any bigger and you'll lose a considerable amount of low end torque. beyond 3,500 RPM it is a question of where you want the power peaks. As you can see from the charts on this page, small tube headers do not lose their edge in horsepower and torque until you exceed 5,500 RPM."
Strut tower brace(GM), CAI, Blade Spoiler, ZL1 wheels and tires, Heritage grill, Dual mode exhaust, and thats it, no more..except for the lowering springs..Ok Hotchkis springs were delivered today, thats it..
wally mayfield is offline   Reply With Quote
Old 07-01-2013, 09:52 PM   #21
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
^^^go home Wally your drunk !!
Old 07-01-2013, 10:02 PM   #22
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Originally Posted by wally mayfield View Post
for giggles:
Nice cut n paste. Where's the chart ?
Mchlgrrsn is offline   Reply With Quote
Old 07-01-2013, 10:05 PM   #23
wally mayfield
Drives: 2013 2SS 6M
i copied it....
also if your running headers into a stock exhaust system, you may not be doing much.
Old 07-01-2013, 10:13 PM   #24
wally mayfield
Drives: 2013 2SS 6M
here ya go Mch:
http://www.sandersonheaders.com/Lets-Get-Technical.html
Old 07-01-2013, 10:23 PM   #25
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Your still drunk there Wally!
The TEST engine is:
433 cu. in. big block Chevy
10.4:1 compression
Holley 780cfm carburetor
Oval-port heads with 2.09" intake valves, and 1.88" exhaust valves
High performance mechanical camshaft, specs 250°/259° duration at 0.050 lift
First off its a big block old school with a weak azz compression ratio and it has measly 2.09 valves WE have 2.165 valves and a 1.60 exhaust and these Ls3 heads flow way more than those and these motors are more efficient.
Stop cutting and pasting with info you just read on the Internet.
Old 07-01-2013, 10:28 PM   #26
wally mayfield
Drives: 2013 2SS 6M
yes dear..i believe it said in my post that 2" was for big blocks....and the reason for the cut and paste was because i didn't see you posting any useful info...
Old 07-01-2013, 11:07 PM   #27
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Honey can you please copy and paste stuff that applies to us?
And if you think I don't contribute anything. Please feel free to check my recent post in my profile then get back to me ok? Be cool hunny bunny
Old 07-02-2013, 12:28 AM   #28
wally mayfield
Drives: 2013 2SS 6M
is there anything else on your to do list to do that I'm behind on?
sorry if the article on headers didn't apply to your vin #, it was general information..and general info apples to most all......*yawn*
