BORLA
Old 07-02-2013, 05:02 PM   #29
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Originally Posted by 360ss View Post
My wife owns a 2011 cts , luxury horsepower just doesn't sctatch my itch!! Be more specific As far as what track capabilities ? I was only addressing to ur message you posted.
What I meant is they designed the rearend of the Z/28 for track use. If you change that to be beefier for the strip it might effect its performance on the track. I am not an expert, but I would think if the engineers could have made it for both wouldn't they or does it come down to the COPO is for the strip, the Z/28 is for the track and the ZL1 does everything.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 07-03-2013, 04:07 PM   #30
Zfatuated
Zfatuated's Avatar
Drives: BAC Mono
Your homework is to learn and report back on different types of differentials and how, exactly, each is better or worse for a given application. It's not a hard assignment, in fact, if you put forth even a modicum of effort, you can earn the adulation and respect of your peers.
Bonus points for discussing the effect of weight (reduction) as it pertains to road course cars, drag race cars and street cars.
Zfatuated is offline   Reply With Quote
Old 07-03-2013, 04:28 PM   #31
Sven59
HAMMER PILOT
Sven59's Avatar
The dog ate it!
Old 07-03-2013, 10:17 PM   #32
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by SSpade22 View Post
Iíve seen in magazines the HP that the new Z28 will put down at the fly, but I havenít seen any actual RWHP numbers. Does anyone know where it will be in that aspect, and how much lighter is the Z28 vs. the 2010 SS.
Its very difficult to get RWHP for a car that has never seen a dyno outside of a GM R&D centre. It gets even more difficult to guess when we don't know what the final flywheel power is going to be. All that is official is that the LS7 will provide at least 500 hp.
But personally, I wouldn't be too worried about what a stock Z/28 makes at the wheel. Namely because its just a number that depends on a whole host of factors beyond the car itself. What type of dyno is it, what are the conditions its being run in, when was the dyno last calibrated, is the operator conservative or generous, and so on. So it is entirely possible that one Z/28 could do a few pulls on a dyno and get a reading of 410 rwhp and the owner would think they've got a slug for a car. But if they went down the street to a different shop the same car could hit 450 rwhp & sunofabitch ... their car is under-rated!
As for weight, the target was 100 lbs less than the SS and from what I recall, they have surpassed that goal without too much trouble. So it will probably end up right around 3700 lbs when its done.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 07-04-2013, 11:51 AM   #33
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
That's my guess as well, right around 3,700.
2cnd chance is offline   Reply With Quote
Old 07-04-2013, 03:42 PM   #34
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
A lot depends on if the LS7s are already made. Are they building fresh brand new engines in BG or are they using up units already made at Wixom? If new then there may be room for tweaks. If pre built then you are counting on intake and exhaust for better breathing. I think 520 will be tops. So rear wheel not much more than the good ol Z06
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 07-04-2013, 03:48 PM   #35
2cnd chance
Do you know what the Z06 had for RWHP? Thanks.
Old 07-04-2013, 04:44 PM   #36
LOWDOWN
Downright Upright
Drives: Daily
Mass, and unsprung weight, reductions were paramount, without breaking the Bank. 1LE rear axle assembly (minus brakes etc.) is about 40# less than ZL1...which is about 20# less than the CTS-V.
Typical untouched C6 Z06s range from about 420 to 440 rwhp (different dynos on different days). The "targeted 450" is assuming a good "tune" from the fine folks @ GM...
LOWDOWN is offline   Reply With Quote
Old 07-04-2013, 04:59 PM   #37
2cnd chance
Thanks!
Old 07-04-2013, 06:23 PM   #38
The DeLoach 27
Drives: 2013 ZL1 CRT Manual 6-speed
Lost on driveshaft
Originally Posted by SUKXOST View Post
yeah 18% DT loss seems high. Mine was less than 12% loss. 426hp and my baseline was 378WHP.
I'm betting 445+WHP
Typically it is only a 12-15%, gross h.p. vs. RWHP.
The DeLoach 27 is offline   Reply With Quote
Old 07-04-2013, 08:30 PM   #39
Cody6.2
Drives: 2012 Camaro 2SS
There is no real percentage of drivetrain loss as it's a static figure from stock to whatever horsepower.
Cody6.2 is offline   Reply With Quote
Old 07-04-2013, 09:07 PM   #40
DGthe3
Moderator.ca
DGthe3's Avatar
Its not a simple percentage, but that is a much more accurate rule of thumb than a static figure is.
You are probably thinking of the power that it takes to accelerate a wheel or drive shaft, and its true that these things take only a fixed amount of power to be accelerated (until you swap them out for something different of course). But the instant that they are up to speed, they no longer rob anything of any power (and they also 'release' power as you try and decelerate). This does not hold true for the gears in the transmission & differential, or the half-shafts going out to the wheels, or the bearings or tire flex any of the other sources of friction. Those losses can be approximated as a percentage of input power, though in reality its a somewhat complex curve that depends on a number of factors. Point being, if you run your car stock on a chassis dyno and calculate that it lost 55 hp ... don't assume that after you've supercharged it its still only losing 55 hp.
Old 07-05-2013, 09:14 AM   #41
LeanPocket
Drives: 2010 2SS
this will be a 11 second car with the right driver, 11 consistent with a auto swap.
LeanPocket is offline   Reply With Quote
Old 07-05-2013, 09:17 AM   #42
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
With an auto swap you might just as well peel the Z/28 badges off while you're at it.
Norm
Norm Peterson is offline   Reply With Quote
