HeadlightArmor
Old 07-01-2013, 05:24 PM   #1
Secret Squirrel
Secret Squirrel's Avatar
Drives: 1965 Chevelle Malibu
low oil pressure warning...
I have yet to have a single issue with my 2010 LS3, and today, after getting home from work, I got back in the car to run errands and as soon as I started to back out of the drive way, my low oil pressure warning came on.
I installed a Mike Norris catch can last week, and I can't help but wonder if that could have anything to do with it. I had my oil changed less than 1k miles ago, and I am not leaking any oil. I just checked, and my oil is full. Any ideas what the problem could be? Is it possible that it is related to the catch can? Thanks.
Secret Squirrel is offline   Reply With Quote
Old 07-01-2013, 05:32 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Shouldn't be related to the catch can, when you say you're oil is "full" I'm guessing you mean that it's within the marks on the dip stick? Are you checking your oil level when the engine is hot or when the engine is cold?
Click to view my build thread
Old 07-01-2013, 05:36 PM   #3
LSXaddict
LSXaddict's Avatar
Drives: 1ss in Blue Ray Metallic
I don't want to jump to conclusions but I have heard of the oil pumps going out on the 2010 LS3's
2013 1SS M6 with Flowmaster Pro 10 axle back and CAGS shift skip eliminator
LSXaddict is offline   Reply With Quote
Old 07-01-2013, 05:44 PM   #4
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
did you upgrade the oil pump when you did the cam install?
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 07-01-2013, 05:49 PM   #5
Kelly@PCMofNC
Drives: 2010 RS/SS
The catch can wouldn't impact that, unfortunately it may be the pump, is it stock?
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
Old 07-01-2013, 05:59 PM   #6
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Mine turned out to be the Oil Pressure Relief Valve
PIP4158C: Low Oil Pressure Due To Seized Oil Pressure Relief Valve - (Dec 29, 2009)
Subject: Low Oil Pump Pressure due to Seized Oil Pressure Relief Valve
Models: 2008-2009 Buick Lacrosse, Allure (Canada Only)
2007-2010 Cadillac CTS-V, Escalade
2007-2010 Chevrolet Avalanche, Corvette, Silverado, Suburban, Tahoe
2007-2008 Chevrolet Monte Carlo SS
2007-2009 Chevrolet Impala SS, Trail Blazer
2009-2010 Chevrolet Colorado
2010 Chevrolet Camaro
2007-2010 GMC Envoy, Sierra, Yukon
2009-2010 GMC Canyon
2008-2010 Hummer H2
2008-2010 H3 Alpha
2008 Pontiac Grand Prix GXP
2008-2010 Pontiac G8 GT
2007-2009 Saab 97x
with the Following Aluminum V8 Engine RPOs:
L76, L77, L92, L94, L99, L9H, LC9, LH6, LH8, LH9, LS2, LS3, LS4, LS7, LS9, LSA, LZ1
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may complain of low oil pressure, no oil pressure, and/or engine noise, which may be the result of a sticking oil pump pressure relief valve. In some instances, this may occur intermittently if the valve frees up when the engine cools down.
Recommendation/Instructions:
If SI diagnosis isolates low mechanical oil pressure at the oil filter housing and oil pressure sensor, replace the oil pump, flush the oil cooler lines (if equipped), clean the inside of the oil pan, change the oil and filter, and re-evaluate the concern.
Notice: If an engine noise is noticed after replacing the oil pump, follow the SI diagnosis and repair the engine as necessary.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Old 07-01-2013, 06:51 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
That's the oil pump bro!
I'd say its the pump as well.
Old 07-01-2013, 07:35 PM   #8
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
same thing happen to me after about 8-10 thousand after cam. went to get a pizza . walked back out , started the car and display said no oil /low oil pressure. took to kyspeed and he help me fix it with a melling . i did the ls2 chain thing too . cause ive heard them going down pretty quick aswell . but ya its ur pump. most likely the relief valve going bad in the pump. but a new pump and ur good to go.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 07-01-2013, 07:45 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
They've been taking shits since 1998 sir.
Old 07-01-2013, 08:12 PM   #10
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
yep since the start of the ls . nothing new
Old 07-01-2013, 08:29 PM   #11
SPCBA
Drives: pleather and Chiclets
please for the love of god do not drive it. melling makes a replacement that is affordable and diy capable job.
i have seen ls3 guys use l99 pumps as well.
SPCBA is offline   Reply With Quote
Old 07-01-2013, 08:43 PM   #12
Secret Squirrel
Thanks for the info. I shut it off the second the car told me to. Not worth taking the chance and making it a much more expensive fix. I called the dealership and they want to charge me $1700 to replace the pump. After much research, I am finding that my mods can not possibly have had any impact what-so-ever on my pump failing, so this may be a battle I fight with GM under the Magnuson-Moss Warranty Act. We'll see. Worst case, our best performance shop in town is offering to install a Texas Speed ported pump for $600 out the door. Not fun for a part that should not fail, but I'm skeptical about replacing it with the same garbage pump that it has in it.
The worst part of this is that I am military and have orders to transfer next week. My car was supposed to get me from Florida to California. My piece of mind isn't at it's highest at this point. Crossing my fingers that I can get this thing all hammered out in time to roll out on schedule. Again, thanks for the info.
Old 07-01-2013, 08:44 PM   #13
Secret Squirrel
Did GM cover it for you? Is your car modded? If you had to cover it, what did it run you?
Old 07-01-2013, 08:46 PM   #14
Secret Squirrel
Both. Dealership changed it out less than 1k miles ago. By full, I meant, it is where it should be.
