JDP Motorsports
Old 07-01-2013, 08:20 PM   #1
FanDamNCSU
Drives: 2010 CGM 2SS/RS - L99
Just ordered NPP for my 2010 SS
Just found a pretty good deal on a 2013 ZL1 Dual Mode Exhaust. I went ahead and pulled the trigger, I can't wait to get it installed. I hope the install goes smoothly.
For anyone who has done this before can I use the existing screws and hardware for the install or will I need to order anything else aside from the diffuser and vacuum kit?
Performance:
Vararam CAI, Vmax Ported Throttle Body, GM Performance Dual Mode Exhaust (NPP), JRE Tune, Hotchkis TVS Stage 2 Track Pack, Vitesse Paddle Shifters, Vitesse Throttle Controller
Functional:
Hex Vents, Elite Catch Can, WeatherTech Digital Fit Mats, Escort Passport Max
Cosmetic:
Heritage Grill, GM Splash Guards, ZL1 Rockers
FanDamNCSU is offline   Reply With Quote
Old 07-01-2013, 08:21 PM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Everything else is reusable, straight bolt on. I see you have an L99, are you tuned? If not when AFM kicks in this exhaust is going to sound really crappy. That is why it's not offered on auto SS's.
Sent from my 2SS/RS
FSP tuned: 377/389
Old 07-01-2013, 09:04 PM   #3
Nick821
Nick821's Avatar
Drives: 2013 BRM SS/RS Convert
I just did the same in my 2013. Straight bolt on. You will need to tune out the AFM or use the Range V8 device that plugs into OBC port. I used my own mechanical vacuum pump system to control the activators. The exhaust sounds great!
Nick821 is offline   Reply With Quote
Old 07-01-2013, 10:42 PM   #4
FanDamNCSU
Thanks for the heads up guys. I'll probably end up getting the range and the do a tune once my warranty expires.
Performance:
Functional:
Cosmetic:
Old 07-01-2013, 11:10 PM   #5
the_fast_one
the_fast_one's Avatar
Drives: 2012 IOM 2SS, 05 SOM Colorado
I got them for my 12 SS I also ordered the NPP in a box so I can control it at will with a fob
Let the modding begin
466/436 - JRE Rough Idle blower cam, BTR push rods, PRC 6.75 springs, halltech CAI, K&N filter, SLP 25% UD pulley, Manley H/V oil pump, Kooks 1 7/8 headers w/o cats, ported TB, Npp exhaust. BMR 1.4"/1" drop springs, ZL1 Swaybars, 1LE strut tower brace, zl1 rockers, zl1 style splitter, night shades ns3 stripe kit.
Future mods
Dss 1000hp axels Dss aluminum driveshaft, bmr full bushings, ? Clutch, ? Supercharger, wheels/drag radials.
the_fast_one is offline   Reply With Quote
Old 07-01-2013, 11:15 PM   #6
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
I programmed the remote to the Homelink. So now, I can use the remote or the garage opener buttons.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 07-01-2013, 11:19 PM   #7
dgreenberg
dgreenberg's Avatar
Drives: 2014 Z/28 #352, 2013 ZL1 Vert (SOLD
Have you hooked up your NPP in a box? I got a kit too. Just wondering if anyone else has successfully done the install.
dgreenberg is offline   Reply With Quote
Old 07-01-2013, 11:24 PM   #8
yotaman96
yotaman96's Avatar
http://www.camaro5.com/forums/showthread.php?t=247109
Old 07-01-2013, 11:59 PM   #9
dgreenberg
dgreenberg's Avatar
Originally Posted by yotaman96 View Post
Doesn't help me to see where to tap if I don't have a super charger. Since its very difficult to see, or even feel the back of the intake manifold. Any suggestions?
Old 07-02-2013, 12:15 AM   #10
yotaman96
yotaman96's Avatar
Look in to getting the EZ tap option. Whoever you bought the NPP in a box from should be able to get it. Otherwise, you should be able to tap in to any vacuum line.
Old 07-02-2013, 12:31 AM   #11
dgreenberg
dgreenberg's Avatar
I already have it. And it didn't come with the EZ tap. What other vacuum lines are there to tap?
Old 07-02-2013, 05:58 AM   #12
nyrfan
Let's go Rangers!
nyrfan's Avatar
I am curious. Where do the vacuum lines get connected to on an L99? Or don't they and if not how are the actuators controlled?
FSP tuned: 377/389
Old 07-02-2013, 08:08 AM   #13
the_fast_one
The spot is on the back of the intake on the passenger side. If you feel back there it is right past a flat piece of plastic. It sticks out with and feels like a T. you just twist that part off and put the plastic hose over it. I have installed it on my 05 corvette and double checked the intake on my Camaro. It is all there
http://www.southerncarparts.com/Inst/nppinabox.pdf
Future mods
Old 07-02-2013, 09:54 AM   #14
dgreenberg
dgreenberg's Avatar
How'd you get your hand back there? Lol. It's such a tight fit
