Old 07-01-2013, 09:09 PM   #1
Hard Parker
OMWTFYB
Hard Parker's Avatar
Drives: 2011 SS
L99 straight pipes
As of right now i have the muffler delete and it sounds awesome but i wanna go louder while still being cheap...i know right heresy....how much louder would stright pipes be from the cats all the way back or is this overkill?
2017 Camaro 1LE
Nightfall Gray Metallic
Rotofab Intake/Kooks Headers/ DMS E85 Flex Fuel Kit
469whp/488wtq on E85
Tuned by LSXperts
Follow my build on Camaro6: http://www.camaro6.com/forums/showthread.php?t=484133
Follow me on IG: www.instagram.com/thehardparker
Hard Parker is offline   Reply With Quote
Old 07-01-2013, 09:28 PM   #2
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
It will be a good bit louder but whether it is "loud enough" is completely up to your ear alone. When you remove an L99 mid-section, the resonator comes out. The resonator is what compensates for the noise created by the AFM when it kicks in. Most people do not like the sound of the AFM without the resonator. I have never heard it personally but, based on what I have read around here, it is not a good sound for our cars.
So, you might want to consider this before going straight pipe all the way from the cats.
In case you don't know, there are two ways to remove AFM: permanently with a tune or a Range device. The Range device plugs into your OBDII port and prevents the AFM from engaging as long as it is plugged in.
There are other things to consider depending on your preferences and goals for your car but this is a good place to start.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 07-01-2013, 10:26 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Drone and the noise from AFM is taken care of in the factory J pipes. The resonators just tone the exhaust down a little.
OP. Just know that if you remove the factory resonator section, you'll not only remove the resonators but the factory H pipe as well. It's been shown on numerous occasions that this car will lose hp/tq if it doesn't have a crossover of some sort. Many remove the L99 resonator section for the weight alone but add in a light weight X pipe in it's place. The Magnaflow true X pipe is probably the cheapest name brand X pipe at around $75. There are several copies of it on Ebay. Note that many of them are mild steel which may or may not be a problem for you. There's one that I've seen that's 409SS which is the same metal that's in your OEM exhaust and will last for a LONG time. I think the 409SS version is around $35.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-02-2013, 08:39 AM   #4
RJT-SS
RJT-SS's Avatar
I know that the J pipes in the stock mufflers are for the drone but I have read numerous posts that state the resonator is to dampen the noise created by the AFM. Here's one thread.
http://www.camaro5.com/forums/showthread.php?t=82941
See post 12.
Forgot about mentioning that the H pipe gets removed with the mid-section. Thanks.
Performance Mods:
Old 07-02-2013, 08:49 AM   #5
Easton091
Easton091's Avatar
Drives: 2011 Camaro SS
I have headers, no cats and a corsa exhaust. It is very loud. I actually cant start my car in the morning in my attached garage or I will rattle the walls of the house and wake up my kids. The popping when coming off the accelerator actually sounds like a gun shot. Im getting that tuned out ASAP
2011 SS. K&N intake, Kooks stepped long tube headers with cat-less midpipes, Corsa exhaust, and tuned....
Easton091 is offline   Reply With Quote
Old 07-02-2013, 05:32 PM   #6
axis
Search Ninja
axis's Avatar
See post 12.
That's what resonators do but it only muffles it a little. The J pipes do most of the work. AFM needs all the help it can get since you can still hear it on a completely stock exhaust.
Halltech CF 102 fed
Old 07-02-2013, 08:38 PM   #7
RJT-SS
RJT-SS's Avatar
You're right that the AFM needs all the help it can get to cancel it out. I guess that's why many of us tune it out or use the Range device.
Well, hopefully the OP is still keeping up with this and we helped a bit.
Performance Mods:
Old 12-06-2017, 07:00 PM   #8
dankv6
Drives: 2013 Camaro 2SS Dusk Edition
anyone know how much hp lose
dankv6 is offline   Reply With Quote
Old 12-06-2017, 11:00 PM   #9
Vaninash
Vaninash's Avatar
Drives: 2012. 45th 2SS VERT
I just completed this mod and it is absolutely the way to go x pipe resonator delete and muffler delete there's no better sound on a Camaro.. get in touch with DynoSteve and have his tune done the Afm will be turned off which is an absolute must..and your L99 will become a beast
Dynosteve's tune...k&n cai...catback xpipe resonator and muffler deletes..Beast mode!!!
Vaninash is offline   Reply With Quote
Old 12-08-2017, 03:21 AM   #10
Galonso$*
Galonso$*'s Avatar
Drives: 2012 Camaro SS/RS
If this is true how much does it lose? I’ve been running straight pipes for a about good year and half..
2012 Camaro 2SS L99, LT KOOKs Headers with Highflow Cats, Straight Piped, BTR Stage 2 Cam w/ tune and DOD/AFM delete
Galonso$* is offline   Reply With Quote
Old 12-08-2017, 08:57 AM   #11
WoodBoss
"Old School"
WoodBoss's Avatar
Drives: 2010 2SS L99
You really don't want to do straight pipes without an xpipe. Ditch the cats if you want it louder. I run headers, no cats and a muffler delete and it is very loud especially when you get on it.
Back In The Saddle - Earley 2010 2SS IBM A6 #10244 Built - Roto-Fab CAI, Muffler/CAT Delete, Mickey Thompson ET DRs, RDP Tune,
BW Stage II Ported TB, Speed Engineering 1-7/8" Longtubes, ZEX Nitrous 125HP Shot, Lingenfelter 160* Stat, NGK TR6IX Spark Plugs & Elite Catch Can.
Amsoil Signature Series 5W-30 - 11.76 sec @ 117.3 - 1.61 sec 60' - 1/4 mile pass
Check Out My Youtube Channel For 5th Gen Camaro Drag Racing & How To Mods https://www.youtube.com/channel/UCyG...GR9gDm6PO-27rg
WoodBoss is offline   Reply With Quote
Old 12-08-2017, 02:13 PM   #12
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2014 Camaro 1SS RS SIM
Don't go full straight pipe, I did and regretted it immediately. When you floor it, it falls flat on its face. I went back the next day and got a Magnaflow X pipe installed and much better with my muffler delete.
2014 SS - L99 1SS/RS - "AleSSandra"
K&N Blackhawk CAI / JBA Ceramic Shortys / JBA HFC / BDG O2 Sims / Muffler & Resonator Delete / Magnaflow Tru X Pipe / Taylor Wires / Vitesse Paddles / VMR V710 (275/295) / Pedders 27 & 32 Sways / BMR 1.25" Springs / BMR Strut Brace / Carbon Creations Circuit Hood/ Z28 Spoiler / ZL1Addons Stealth Wicker & Rockguards / Ikon Lip / CFD Adaptor with B&M Shift Handle / SCT Tuned by DynoSteve
SSEssence is offline   Reply With Quote
