Cold Air Inductions
Old 07-02-2013, 03:18 PM   #1
SSmedwin
Drives: Camaro 1SS RS
Which muffler delete?
Are they the same thing?
Which one should I get?
http://www.slponline.com/product/302...Assemblies.htm
Or
http://www.camarocentral.com/2010_20..._p/fue-114.htm
SSmedwin is offline   Reply With Quote
Old 07-02-2013, 03:29 PM   #2
SSmedwin
Nvm.. 2nd one is the one I need.
Read wrong
Old 07-02-2013, 03:49 PM   #3
Birm
Birm's Avatar
Drives: Florida Speed & Power
Just go to a shop, have them chop off stock and replace with pipe welded in.....It'll be like 75-100 and sound the same..
Birm is offline   Reply With Quote
Old 07-02-2013, 03:52 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Read wrong
Do you have a aftermarket 3in exhaust? That particular one says it's 3in and our OEM exhaust is 2.5in.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-02-2013, 04:04 PM   #5
SSmedwin
No I don't have any after market parts.. Which one of the two do I get that will fit
Old 07-02-2013, 04:05 PM   #6
SSmedwin
I'm leasing the car. I don't wanna chop things off lol
Old 07-02-2013, 04:12 PM   #7
SSmedwin
Is there a muffler delete pipe that I can get or do I need to buy a whole new kit or exhaust. I can't find any
Old 07-02-2013, 04:13 PM   #8
axis
Search Ninja
axis's Avatar
If you don't want to chop anything off, you'll have to find a muffler delete catback. I'm sure someone sells one around here. Look at the many vendors we have. I'd start with JDP and Apex. I've had dealings with both and they are absolutely top notch before, during, and after the sale.
Halltech CF 102 fed
Old 07-02-2013, 04:16 PM   #9
axis
Search Ninja
axis's Avatar
The OEM catback is all one piece so if you want anything different, you'll have to either cut at the axles or get a complete catback. If you're careful with the cuts, you should be able to weld or sleeve the OEM axleback back on without too much trouble.
Halltech CF 102 fed
Old 07-02-2013, 04:16 PM   #10
SSmedwin
Can I just get this?
http://www.amazon.com/gp/aw/d/B006OKAXKW
Old 07-02-2013, 04:20 PM   #11
axis
Search Ninja
axis's Avatar
You'll have to cut for that one. That's a axleback muffler delete.
As Birm suggested, a muffler shop shouldn't charge you more than $150 or so but that's reusing your OEM tips.
Halltech CF 102 fed
Old 07-02-2013, 04:24 PM   #12
SSmedwin
Say I do what birm suggested. When I return the car, what are my options?
Do I need to order a new pipe or does the shop weld their pipe in
Old 07-02-2013, 04:25 PM   #13
axis
Search Ninja
axis's Avatar
Turn it in like it is or look below. The shop has their own tubing. Ask for SS if you can. 409SS is what's on the car now. 304SS is better but it's a little pricey.
Halltech CF 102 fed
Old 07-02-2013, 04:28 PM   #14
SSmedwin
Returning the car with a muffler delete wouldn't be a good idea. U kinda lost me, what would I do if I wanted to return it to the stock sound or something where the dealer wouldn't know
