Cold Air Inductions
Old 07-02-2013, 02:22 PM   #1
jfayardiii
Drives: 2011 Silver 2SS/RS L99
Cam, Nitrous, Stall car running 10.2?
So i've got a friend that says hes building a 2010 L99, cam, 150 shot, stall and DR's to run 10.3-10.2.
Is that possible?
2011 2SS/RS L99
10.76@130.5 1.67 60'
LG headers and exhaust, 3200 Yank, EPS Cam, D1SC Procharger, all work performed by Blanchard Performance
jfayardiii is offline   Reply With Quote
Old 07-02-2013, 02:25 PM   #2
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Probably have to take a bunch of weight out of the car to get there with only those mods
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 07-02-2013, 03:12 PM   #3
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
very possible. i ran a 11.3 at 131 on a 125 shot with cam , full exhaust, rotofab , tune. on street tires with a 1.97 60 foot. it was also just sprayin like the last 1/8 maybe a lil more. on a progressive shot. so ya i say its possible. rhino should be close to doing it atm. or he may have went faster.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 07-02-2013, 03:14 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
With weight reduction sure, without, I doubt it. I had a 4th gen that went 10.9 stock cubes and 10.00 with 150 shot, and it was 3300 cutting a 1.38.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-02-2013, 04:10 PM   #5
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
it would be hard for rhino that ran a 10.8 not to pick up that much on a 150 shot. just sayin. it wont be easy and will take some good fuel and some work but it possible. its been done with a 200 shot alrdy.
Old 07-02-2013, 04:16 PM   #6
Pro Stock John
Writer
But his car is not the average. Let's say someone hit 11.3 cam only and sprayed 150 would you expect them to hit 10.2? My 4th gen did that but it was a lot lighter. If I went 11.2 h/c and sprayed 150 I'd hope for 10.5 I think.
PROJECT HEAVY CHEVY
Old 07-02-2013, 08:14 PM   #7
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i fully expect to with tires and a clutch . the mph is there. but all im sayin its possible. very possible. these cars do well on nitrous . tq for big weight is a must. a cammed car spraying around 2800 rpm mark is gonna see around 700 tq to the wheels.
not sayin every car out there can or will but if that person makes it his goals and dont live 6000 above sea leave . i was also in 2000+ da . as u know it all in setup and what not. i mean right now i just play but if i plan on keeping this car for a while . which i do now. it should run 10.5 with very lil work. i know 10.5 is not 10.2 . but u get what im saying.
Old 07-02-2013, 08:50 PM   #8
429
Drives: 2010 camaro ss
The issue with sprayed automatics is the 6l80's first gear. Hit it hard and launch in second gear and you can go places.
429 is offline   Reply With Quote
Old 07-02-2013, 09:49 PM   #9
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Is that possible?
It is possible in perfect conditions with a low 1.4 60ft assuming you can get the traction off the line.
However IMO it's not very probable. Comparing the fastest L99 and then introducing nitrous is like saying you can go out a Robin Hood an arrow with another arrow with 1 shot. It's possible but unlikely.
There is a big difference in going from an 11.3 to a 10.3. The lower you go, the harder it gets to add a tenth.
Camarojt is offline   Reply With Quote
Old 07-02-2013, 10:32 PM   #10
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
My only nitrous passes at the track in Memphis were disappointing on the mast cam. No traction that night, couldn't spray till about 50 mph. 1.7s 60 on motor then hit the spray, I went 6.88 at 104 1/8th and 10.60 at 133 on my best pass. With the new cam, and good track prep, with the progressive controller I just installed and some suspension work, I SHOULD go 9.9s to 10.1x at about 135-137. I have tweaked converter lockup too for the gas, as in locking in 3rd and 4th.
Most cammed L99s with gas wont see past mid-high 10s on avg though.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
shop.gwatneyperformance.com ryan@gogwatney.com josh@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 07-03-2013, 09:11 AM   #11
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
like i said it gonna take someone that wants the most out of their car. 9 are possible. rhino thats what i have to do in my car too. i have a progressive shot and had bottle temps up to 950 or so. tried to take a full hit and it eat my clutch up. i started sprayin about the 1/8 and progressed each gear change to a .5 sec ramp from 50% to 100%. bottle temps were way down too to help soften the hit. it helped alot. stock clutch. but im mph was alway 130's . thats all im was workin on cause no tire and no clutch at the time. also 125 shot
Old 07-03-2013, 09:33 AM   #12
jfayardiii
thanks for all the response. Sounds like yes, its possible, but you really have to massage the car and the driver to get it.
2011 2SS/RS L99
Old 07-03-2013, 12:07 PM   #13
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
exactly. very few will see it but it should run mid 10's maybe on the higher side of that. but it is possible.
Old 07-03-2013, 07:03 PM   #14
Supercharged SS
Drives: 2010 Camaro
Is that possible?
No way in the world. He won't even be close.
Figure an L99 is about 330 rwhp stock. At 150, so you're at 480, and a stall. You'll be lucky to crack a 10.
10.2/.3 you need a serious setup which is way more than a 150 shot. Go look at all the cars that run that fast. Way more than a stall and a 150. If it was that easy all you guys would have low 10 second cars!!!!!!!!!
