HeadlightArmor
Old 07-02-2013, 05:31 PM   #1
TheBandit18
TheBandit18's Avatar
Drives: 2010 Camaro 2ss M6
Disappointed in numbers.
I just installed my night fury cam in my 2012 ls3. I also have have TSP 1 7/8 LT headers and roto-fab intake. Really disappointed in numbers. It was 81 degrees really nice day. Dynoed on a dyno jet
TheBandit18 is offline   Reply With Quote
Old 07-02-2013, 05:34 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
WOW, that's a lot lower than what others have posted. I'm sure it's in the tune.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-02-2013, 05:35 PM   #3
JEFF75645
Drives: his wife crazy buying mods
Gotta be.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 07-02-2013, 05:38 PM   #4
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
yep seems about 10% off overall
tramtwo is offline   Reply With Quote
Old 07-02-2013, 05:39 PM   #5
TheBandit18
Which part? I was talking him I have been seeing in the 470 to 480s and he said there is no way
Old 07-02-2013, 05:48 PM   #6
driyac
driyac's Avatar
Drives: 2012 45th Anniversary 2SS
AdamSS dyno'd at 420 rwhp/425rwtq just from a CAI intake and 1-7/8 tsp headers.... ITs gotta be in the tune man.
driyac is offline   Reply With Quote
Old 07-02-2013, 05:52 PM   #7
axis
Search Ninja
axis's Avatar
There are guys claiming 500+whp with the NFC. Don't think they have head work either but I could be mistaken.
Halltech CF 102 fed
Old 07-02-2013, 05:59 PM   #8
429
Drives: 2010 camaro ss
That car or dyno has problems. It peaked at 5600rpms. I'd look twice at the valve springs, pushrods, and/or rockers. It's also possible the cam was installed 4 degrees off with that power curve (a tooth)
429 is offline   Reply With Quote
Old 07-02-2013, 06:22 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Who installed it bandit.
Old 07-02-2013, 06:37 PM   #10
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Bingo! 5600 peak for a night fury cam; no way!
TSP 231/236 111 cammed 1LE
WHAMMO is offline   Reply With Quote
Old 07-02-2013, 06:41 PM   #11
TheBandit18
My uncle, dad, and I. My uncle has swapped many cams he did the valves and double checked them. We cleaned every push rod off before install. All rocker arms are in the exact same spot. And on the gear we even took a picture of the dots to make sure it's exact.
Old 07-02-2013, 07:01 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Did you make sure you were at TDC when you aligned it?
What springs and what pushrods sir.
Old 07-02-2013, 07:06 PM   #13
TheBandit18
Sure did. The PAC springs. Everything that came in the night fury racing package. Could hearing it help any to tell if something is off? Or will that not make a difference cause I can get a video
Old 07-02-2013, 07:22 PM   #14
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Hearing it probably won't help, but we'll all take a video!
I agree with these other guys. Retrace your steps and try to figure out what the deal is. You're right to be disappointed. Something isn't right.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
