SDTW Custom Wheels & Tires
Old 07-02-2013, 07:04 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
Cam change ??
I'm going to be doing a cam change soon on my 1LE. Are there any special tools needed? I have an LS balance installer and puller. I also just ordered a LS on head valve spring removal tool. What other LS tools needed? Thanks.
Craig B is offline   Reply With Quote
Old 07-02-2013, 09:21 PM   #2
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
Might want a degree wheel, dial indicator and a push rod length checker unless your going to trust the cam manufacturer to get it right. They usually do, but S*%# happens.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 07-02-2013, 10:03 PM   #3
Craig B
Craig B's Avatar
Drives: 2013 1LE
I can get the degree wheel and dial indicator from my neighbor. I bought a kit that comes with new pushrods, timing chain [3 bolt] Comp Cams Trunion Upgrade Kit, oil pump and gaskets.
Old 07-03-2013, 12:37 AM   #4
SSMickey
SECC
SSMickey's Avatar
Sounds like you have thought this out. The cam kit probably has the right pushrods, but I would still verify the length you need.
