Old 07-04-2009, 02:58 PM   #15
SubSolar
SubSolar's Avatar
Drives: 2009 Corvette, 1987 Buick GN
Originally Posted by 69 Camaro 09 View Post
Thanks for all your help and input guys, i think im going to go with a MT ET Street Radial II, 305/45/18. Shouldn't have any problems there
SubSolar, i go to Fontana to race (AutoClub DragWay, or w.e its called haha)
I will just have to accept that my new street tires and rims won't be around for a while :(
What wheels you going with?
SubSolar is offline   Reply With Quote
Old 07-04-2009, 03:05 PM   #16
Black GT
Banned
Drives: 2006 Mustang GT
Originally Posted by 383ss View Post
no, 20" nittos will not hook up with 470rwhp.
Not exactly true, there are Mustangs running in the 10's on 20" NITTO 555R's
Black GT is offline   Reply With Quote
Old 07-09-2009, 03:34 PM   #17
Black GT
Banned
OP did you make it to the track yet?
Old 07-28-2009, 07:52 PM   #18
69 Camaro 09
69 Camaro 09's Avatar
Drives: 69 Camaro, 010 2SSRS
Ok, there is no such 18" wheel that will fit the Camaro, i have made 20 calls to so many different companys, they all say that the break caliper is too big.
am i really stuck with using a 20" wheel? (meaning stuck with the Nitto as a drag radial as well?)
69 Camaro 09 is offline   Reply With Quote
Old 08-09-2009, 10:50 AM   #19
mstrfdsstr
mstrfdsstr's Avatar
Drives: 2010 SS/RS CAMARO
Originally Posted by garagelogic View Post
First, you should never reduce the air pressure on a street radial tire, it does not hep you get a better footprint and, in fact, has an opposite effect.
A drag radial is certainly going to help, but Nitto, IMHO, is not the best option out there. However, since it looks like you want to keep the 20" wheel on the car at the track, it might be your only option right now.
second that 2.8 60 ft fri nite that was a fun ride at 25lb of air
IOM 2 SS/RS LS3 vin9862
mstrfdsstr is offline   Reply With Quote
Old 08-09-2009, 11:33 AM   #20
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
Nobody wants to tell you they will fit because they can't be sure. More than one person has already managed to fit 18" Corvette Z06 rims. It is definitely possible. See if you can find someone that has done it, and find out exactly what they used, it is around here somewhere.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
rayhawk is offline   Reply With Quote
Old 08-09-2009, 01:31 PM   #21
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
I'm feel compelled to point out that regardless of what tires you have, you're going to need to upgrade your suspension in order to get the most out of your car. If your goal is to get to the finish line faster, then you need to consider the power source, the grip of the wheels, and how the power gets to the wheels. If you forget the between parts, then you'll miss out on a lot of potential.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 07-14-2011, 06:40 PM   #22
fuffl
Drives: #3124!!!
This may have been totally resolved by now, but I just threw this 20" combo on my Camaro and am really pleased with the results. I daily drive my Camaro a very short distance so the tire wear isn't a worry for me. I'm at 509rwhp and am used to sliding grotesquely on the stock tires in second and third gears. With the Nitto I still get a really solid chirp in second and complete traction in 3rd. It was a big difference on my car. In first you can still light them up, but after some practice you'll see your 60' time drop. I haven't run on a clean track yet to have a specific time but it's noticeable.
fuffl is offline   Reply With Quote
Old 07-14-2011, 07:18 PM   #23
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
NT555Rs are a ton better than regular street tires when heated up at the track. But they need a nice long burnout to get them softened up.
Yes, 18" wheels with MTs would work a lot better, but that requires a second set of wheels/tires and you have to take the time to change out your wheels everytime you go to the track.
The NT555Rs are all we've got for a daily driver drag radial. We're still waiting for the 305/35/20 MTs to come out (supposed to be any day now). But they will not make a good daily driver tire, but it will give us another 20" drag radials option along with the 315 NT05Rs.
Old 08-13-2011, 06:17 PM   #24
chevy454
chevy454's Avatar
Drives: '69 Yenko Camaro - 11.73 @ 118
What's everyone doing for air pressure on the 20" Nitto DR's? I had no idea so I stuck them @ 18psi, and which netted some 1.7 60' times...we're trying to dial in some other stuff or else we would've played with the air pressure.
'69 Yenko Camaro - 11.73 @ 118, on F70-15 Polyglass tires, Pure Stock
'10 Yenko Camaro - 11.75 @ 117, LS7+A6+Converter
chevy454 is offline   Reply With Quote
Old 08-13-2011, 06:35 PM   #25
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
Depends on if he has an Auto or Manual... With the Auto the stock suspension does just fine at 470. If the Op switches to MT ET Street or better he will hook w/ no problems. 20" Nittos will not hook at that HP.
We have a couple of autos running 1.5X 60' with zero suspension mods. The car squats nicely on stock springs and leaves stright. I will say hooking at this HP may require the JRE posi mod to keep from spinning one tire.
Old 08-13-2011, 06:40 PM   #26
mlee
www.CamaroFest.org
mlee's Avatar
Here's your 18" Z06 replica wheel that has the correct offset for Camaro and clears the brembos by .5 inch. I've also used a set that required a spacer to clear the brakes. Both worked great.
Old 08-13-2011, 09:00 PM   #27
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
I run the nitto 555R's and cut 1.7x sixty foot times with 600RWHP. I think a M/T or similar would drop that 60.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
TEXAS! Introduce yourself here! TAG UR IT USA - Texas 2071 01-31-2018 10:03 PM
TAG's 2010 THRSS #2 TAG UR IT Member Car Journals 3129 08-14-2014 10:29 AM
Front Tow Hook? Mayhem 5th Gen Camaro SS LS LT General Discussions 17 10-20-2011 06:34 PM
how hard to hook up a sub? Adam Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 10 06-04-2009 07:01 PM
Reno hook up anyone? Iroczlover USA - Southwest 2 09-29-2008 06:49 PM
