Old 07-02-2009, 03:59 PM   #1
EVS Motors Inc.
Drives: '69 Camaro Twin Turbo
Look under your car for a oil leak!
Hey guys had the Black Knight on the lift today and noticed a oil leak. I think you guys should check out your babies too.
EVS Motors Inc. is offline   Reply With Quote
Old 07-02-2009, 04:03 PM   #2
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Where ? What kind of oil ? How much ? Were you running it normal or hard ?
Some details please.
Old 07-02-2009, 04:04 PM   #3
EVS Motors Inc.
Not even 600 miles yet just break in driving. I'll post up pictures in a bit.
Old 07-02-2009, 04:09 PM   #4
EVS Motors Inc.
Damn Canadian quality control!
Old 07-02-2009, 04:31 PM   #5
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
did you change your oil yet . if so recheck the plug if not recheck the plug . that is the drain plug thats leaking correct . maybe not tight enough or little rubber seal is no good on the plug
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 07-02-2009, 04:36 PM   #6
D1BADZ
hmmmmm
D1BADZ's Avatar
Drives: 2010 IOM in-n-out 2SS
damn canucks!
"Responsibility is a Heavy Responsibilty" (Cheech)
D1BADZ is offline   Reply With Quote
Old 07-02-2009, 05:33 PM   #7
shiftz33
shiftz33's Avatar
Drives: SS Sedan, SSR, T-Bird, Highlander
I had oil there the night I took delivery of the Camaro (72 miles).
I had it back at the dealership the next day and they put some florescent dye into the oil and cleaned it up. The oil has not returned since that point in time. The amount of oil I had was about twice what is pictured in this thread.
15 Chevy SS | 04 Chevy SSR | 04 Ford Thunderbird PCR #428 | 06 Toyota Highlander Hybrid
shiftz33 is offline   Reply With Quote
Old 07-02-2009, 05:41 PM   #8
FNKNSTN
Banned
Drives: A Black Car
What I usually do is take a far zoomed out picture of the entire area... then zoom in on the problem so you can tell where the problem is. Then I take several pictures and choose the one that is perfectly focused.
FNKNSTN is offline   Reply With Quote
Old 07-02-2009, 06:00 PM   #9
10redrocket
Drives: 2SS Camaro LS3
I had a leak when the car came off the truck.
Found it during the service check. Mine was where the oil cooler lines
are attached to the block, just above the oil filter.
Tightened a few bolts around the cooler lines, just slightly.
Don't crank them down, they are threaded into aluminum.
RECEIVED 5/22/09 - 2SS, SIM with CGM stripes, Black Leather, Polished 20's, Sunroof, LS3.
Past Rides: 69 Camaro RS Small Block
67 Chevelle SS Big Block
05 Cobalt SS Supercharged
07 Cobalt SS Supercharged
10 Camaro 2SS LS3
Soon: 18 Camaro 2SS 1LE
10redrocket is offline   Reply With Quote
Old 07-02-2009, 06:02 PM   #10
jdbaker82
Banned
Drives: None
Are you kidding me? Brand new car and you had to tighten bolts to stop an oil leak?
jdbaker82 is offline   Reply With Quote
Old 07-02-2009, 06:25 PM   #11
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
My oil pan bolt was loose. Changed oil just under 900 miles and there was a dab of oil on bolt head.
When I applied a closed end wrench to loosen, there was no resistance..Could have taken off with fingers.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 07-02-2009, 06:55 PM   #12
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Oh no!
Old 07-02-2009, 08:12 PM   #13
broncosman
broncosman's Avatar
Drives: 2010 Camaro 1SS
Send a message via Skype™ to broncosman
ok, so the first thing I'm doing when I get my Camaro is drive it from one end of the dealership to the other where the service dept is and make them check and make sure any bolts that hold back fluid are tight. ty for the heads up. sorry about the canadian workmanship. I just yelled at my wife (she's canadian) ahhahahhaah j/k didn't yell at her, just asked her wtf
broncosman is offline   Reply With Quote
Old 07-02-2009, 08:35 PM   #14
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
Not cool
69 Hugger is offline   Reply With Quote
FIRST DETAIL: '10 Camaro SS #4768 Steve P Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 4 07-09-2009 01:20 AM
09 Mustang GT and 09 Challenger R/T test drives CamaroSpike23 General Automotive + Other Cars Discussion 19 04-10-2009 05:27 PM
Why you can't buy a new car directly from the manufacturer scotchsride09 Off-topic Discussions 13 02-14-2009 06:15 PM
NEW!! Voice Your MARKETING Suggestions/Input for Focus Group on 2010 Camaro. Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 114 05-08-2008 10:24 PM
