Old 07-03-2013, 01:13 AM   #1
MaroKid81
You Only Live Once.
MaroKid81's Avatar
Drives: 2010 Chevy Camaro 1LT
24'' wheels offset ?
I just got my wheels in today and i go to put the front wheels on and I have a issue the wheel hits the strut ... like bad the place where i got the wheels said that it was a blank wheel and they had to get holes drilled and the offset right to fit my car the offset said +32 but in the wheel it said et15 just look at the pic and you can see that its not going to work ...so what is the right offset for 24'' wheels i need your help guys
MaroKid81 is offline   Reply With Quote
Old 07-03-2013, 11:32 PM   #2
angryv6
Lake Erie Monster
angryv6's Avatar
Drives: 02 Hyundai Santa Fe and 13 300
That sucks!
angryv6 is offline   Reply With Quote
Old 07-04-2013, 08:03 PM   #3
DraggnFrameGMC
DraggnFrameGMC's Avatar
Drives: 2011 Synergy Green Camaro LT
Lexani made mine to order and I believe the front was a +28 and the rears were a +30. What size tire are you running?
DraggnFrameGMC is offline   Reply With Quote
Old 07-05-2013, 11:10 PM   #4
MaroKid81
You Only Live Once.
MaroKid81's Avatar
275/25/24
Old 07-05-2013, 11:14 PM   #5
MaroKid81
You Only Live Once.
MaroKid81's Avatar
the place i ordered them from keeps telling me the the offset is right and that my tire size is the problem the offset was a +32 and the tire size was 275/25/24 all the way around. I think the offset is wrong cause even with a 10mm spacer the wheel is still hitting the strut.
Old 07-06-2013, 01:39 AM   #6
DraggnFrameGMC
I'm running a 255/30/24 and mine barely touched the strut when I bolted them on, but once I set them on the ground it was off the strut. No problems in 2 years. Those look like Status Knights, another forum mumber here runs those in 24 and his are fine. Did you get the 9" wides for the front?
Old 07-06-2013, 01:51 AM   #7
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
+25 or less, for the fronts(for that size a rim)..can't you return 'em? Do the rears clear?
Old 07-08-2013, 12:49 AM   #8
MaroKid81
You Only Live Once.
MaroKid81's Avatar
DraggnFrameGMC I did get 24x9 all around i think the place i got them from said that the offset was a +32
2010SLVRBULIT the rears are fine.. the place i got them from wants me to pay to return them and thats like 300-700 bucks and im not paying i think they just cut too much off cause every one in my town with 24 on there camaro have 275/25/24 and have know problem.
Old 07-08-2013, 01:26 AM   #9
DraggnFrameGMC
youre only talking a few millimeters. Just get a 1/4" plate spacer to push them out and youll be fine. 1/4" is 6-7 mm which would mock the wheel to the +25-+26 which will work
