Old 07-03-2013, 09:53 AM   #1
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
Question Throttle Body Swap & CEL's
I'm going to be switching out my throttle body (for the Vmax ported) on Friday as soon as it gets here. I've read that if you disconnect the battery before disconnecting the throttle body you won't get a CEL. I would prefer not to disconnect the battery so that I don't have to reset the radio and everything. I have a bluetooth OBDII module that I use with the Torque app on my Android phone. Using the app, I can read and clear any CEL's that I may get. If I swap the throttle body without disconnecting the battery and use the app to clear the code(s) would I be good to go and would the not return? Not sure what the codes are, or if there is any reason to not want to get them in the first place? If there are any side effects to getting them in the first place I'll just not be lazy and disconnect the battery, no biggie. Any info is greatly appreciated!
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller
Aesthetic Mods
Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items
snymat68 is offline   Reply With Quote
Old 07-03-2013, 09:54 AM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
No need to disconnect the battery for a TB swap, you won't get a CEL.
FSP tuned: 377/389
Old 07-03-2013, 09:55 AM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You shouldn't get a CEL either way.
Old 07-03-2013, 09:56 AM   #4
family man
Drives: .
I didn't disconnect the battery when I swapped out mine. You'll be fine.
family man is offline   Reply With Quote
Old 07-03-2013, 09:57 AM   #5
snymat68
snymat68's Avatar
Awesome. Thanks guys!
Performance Mods
Aesthetic Mods
Old 07-03-2013, 01:51 PM   #6
jkchambless
Austin LT
jkchambless's Avatar
Drives: 1LT - Airaid,JBA Axleback,VMax PTB
No CEL when I did mine, however I always disconnect the battery when doing something of that nature.
jkchambless is offline   Reply With Quote
Old 07-06-2013, 12:16 AM   #7
Jims Mongoose
Jim
Jims Mongoose's Avatar
Drives: 2013 Black 2SS 1LE
Question from Newbie
Where does the throttle body go? What does this new throttle body do to imporve the performance. Which is best? How do you change it?
What is a CEL, is that a computer code?
I know, dumb questions, but I'm new at these new fangled cars?
Jim
Jims Mongoose is offline   Reply With Quote
Old 07-06-2013, 12:20 AM   #8
Est.July.4.1776
The pride of the CN
Est.July.4.1776's Avatar
Drives: '13 AGM 2SS/RS M6 & '70 Chevelle SS
CEL = Check Engine Light
Throttle body is super easy to swap, it's connected to your intake, and to the air cleaner tube assembly... It takes literally ten minutes, a screwdriver and a 10mm socket.
The new throttle body he's installing (VMAX) is polished on the inside which improves airflow by reducing the restriction of air caused by the resistance of the rougher interior surface... polishing removes the roughness and improves the airflow... which increases horsepower, throttle response AND fuel economy.
"I've been working on the railroad, all mother f###ing day." ...and yeah, we hauled your Camaro.
Class 1 Freight Rail Conductor - Master Mason - NRA Life Member - Tennessee Squire - Firefighter I & II Certified
My other ride has 4,400+hp and corners like it's on rails... because it is.
Est.July.4.1776 is offline   Reply With Quote
Old 07-06-2013, 12:22 AM   #9
Est.July.4.1776
The pride of the CN
There it is... the silver thing with the gold butterfly valve that you can see after I removed my cold air intake tube... four 10mm bolts hold it on, and one electronic harness plug. Unplug the harness, remove the bolts, put the new one on, bolt it in, plug it in, reattach the intake hose... done.
Old 07-06-2013, 12:25 AM   #10
Est.July.4.1776
The pride of the CN
Also, here they are side by side... you can see the roughness of the stock one I removed on the left compared to the smooth, spiral interior of the one on the right, which is the polished VMAX model.
Old 07-06-2013, 01:17 AM   #11
mc_acoustic
Drives: 2010 1LT Limited Edition Camaro A6
Saying you wont get a check engine light is a lie... You MIGHT get one... so dont be surprised if you do...
I knew 3 others who got it when they installed
I just installed it 3 days ago, didnt disconnect the battery (This was for a v6)
I got rid of the codes with torque app. no CEL yet.
mc_acoustic is offline   Reply With Quote
Old 07-06-2013, 02:52 PM   #12
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Asking what the finishing of the inside of the throttle body does for the car can be sort of explained by understanding why a golf ball has dimples. The golf ball actually has less wind resistance with the dimples than it does if it was smooth - crazy, huh? Same idea here. The machined patterning cut into the revised throttle body helps airflow.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 07-06-2013, 02:58 PM   #13
Dacannon
Dacannon's Avatar
Drives: 2010 ABM 2LTRS, E46 330XI
I just installed mine an hour ago and also got the two codes mc_acoustic received v6 vmax throttle body.
Dacannon is offline   Reply With Quote
Old 07-07-2013, 02:47 AM   #14
Jims Mongoose
Jim
Thanks to all for the pictures and explanations.
Now I have to get one of those, a CAI and do a Tune as my first mods to
my car.
Jim
