Old 07-03-2013, 06:57 PM   #1
SR71
SR71's Avatar
Drives: 2012 45th Anniversary 2SS
Thickest Rear Tires That'll Fit
I'm thinking of giving my Camaro a bit of an old school rake by lowering the front and putting thicker tires on the back. Does anyone know what the thickest tires that will fit on the rear (stock rims) without rubbing are?
Thanks
SR71 is offline   Reply With Quote
Old 07-03-2013, 08:39 PM   #2
oldfriend
Drives: Fiat 500 E
Thanks
Try these Goodyear
They are 63" , the absolute widest ones one can find
Old 07-03-2013, 08:44 PM   #3
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
You'll have to keep the OD very close on these cars, because the abs doesn't like different tire sizes. You could run a little smaller wheel in the back to get more sidewall than the front, but that's about it.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 07-04-2013, 12:52 AM   #4
Gibroni
Drives: '12 IOM LT 'vert
What's on a COPO Camaro?
Gibroni is offline   Reply With Quote
Old 07-04-2013, 08:24 AM   #5
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Front and rear tire height difference needs to be within 0.5" or less in total height, otherwise your Stabilitrak, ABS brakes, and traction control will all throw codes and not function. Most newer vehicles don't work like old cars, they have sensors on each wheel that look for a certain range of rotations and compare the front to the rear.
Fquick.com/NineBall
Old 07-04-2013, 08:33 AM   #6
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
you can put 305's on the stock wheels and still fit. Now is it safe to put that wide of a tire on the 9" wheel. Experts will tell you no, but many do it.
Old 07-04-2013, 08:14 PM   #7
L99CAMA2011
L99CAMA2011's Avatar
26.6" 19" wheel in front , 27.5" 20" wheel in rear , rain, sunshine, hale, tornado even if it's raining aligators and pythons, ABS works on my 2012 and haven't seen a code or light on dash as of yet going on for a couple of months.
Old 07-05-2013, 09:21 PM   #8
superdrummer38
Drives: Camaro 2SS/RS
There is one guy on here running 335s.
http://www.camaro5.com/forums/showthread.php?t=303335
superdrummer38 is offline   Reply With Quote
