Caryle Racing
Old 07-03-2013, 08:43 PM   #1
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Looking for the impossible? Replacement mufflers...
So I'm going to run cut outs on my car. I like having the quietness of the OEM mufflers and the loud cutouts on demand. My issue is that I want to ditch the heavy stock cans.
What I want though, is something light, quiet, and relatively cheap. Anyone know of a brand I can get that fulfills this?
I can never find all three qualities....
DarkneSS is offline   Reply With Quote
Old 07-03-2013, 08:44 PM   #2
bkscott
bkscott's Avatar
Borla Touring, Magnaflow, GMPP.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 07-03-2013, 09:03 PM   #3
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
An option that you can do is have a local exhaust shop cut your factory mufflers out, and add resonators. The resonators weigh less, take up less space, and muffle the exhaust note, leaving it quiet until you open the cutouts. It worked perfect for me.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 07-04-2013, 12:12 AM   #4
DarkneSS
All quite relatively expensive and much louder than OEM.
Really? Which ones did you use? I could probably order a pair for low cost.
Old 07-04-2013, 12:17 AM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
What's your definition of cheap? A pair of resonators with no mufflers is still going to be quite loud.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-04-2013, 12:32 AM   #6
DarkneSS
$50-100 per muffler. And yeah see thats not what I want, I have the cut outs to be loud. Ideally I'd like it to be barely louder than stock, I just want the weight reduction.
Old 07-04-2013, 12:51 AM   #7
axis
Search Ninja
axis's Avatar
I have the dynomax VT axleback and really like it. It's just a tad louder than stock at idle but it's a lower tone. At cruise you can't really hear it inside the cabin at all, just like stock, and there's absolutely no drone. It's designed to not drone. When you hammer it, the valve in the muffler opens up and it's pretty much straight pipes. There is a good YT video from Dynomax that from inside and I think out with them installed. The axleback is around $400 but that comes with a nice set of tips, the needed piping, and has all the hangars welded on in the right places for proper fitment on your car. It's designed to be put on by anyone in their garage with a set of jackstands and a sawzaw or hacksaw. The mufflers run $90-100/each by themselves. Even with LT's and no cats, there is no drone but the sound is a bit louder.
Halltech CF 102 fed
Old 07-04-2013, 12:57 AM   #8
DarkneSS
Do you mean these?
http://www.ebay.com/itm/Two-2-Dynoma...f46e05&vxp=mtr
Thats so cool how it has that valve! So basically this will be close to stock but at high RPMs it will open up?
I'd rather get these because my shop will make them fit and put the stock tips on for dirt cheap, much less than the $220 more the specified axle back would cost. They'll do it probably for about $50 and I can keep the OEM look.
Old 07-04-2013, 01:33 AM   #9
axis
Search Ninja
axis's Avatar
Those are them. 2.5 offset inlet/2.5in center outlet. Yes they will get quite loud when you get on it. Not too bad with stock cats though. Cats really quiet things down.
This one is of a 10 SS with VT's installed.
http://www.superchevy.com/multimedia...ler-test/6401/
Halltech CF 102 fed
Old 07-06-2013, 01:17 AM   #10
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
Paint the stock cans black with header paint.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 07-06-2013, 10:25 AM   #11
Levischilz
Drives: 2012 Camaro SS Transformers Edition
Have you lifted them? When I removed mine there actually much lighter than they look.
Levischilz is offline   Reply With Quote
