B&M Racing
Old 07-04-2013, 02:09 PM   #15
Wezbad1
Wezbad1's Avatar
Drives: 2013 ZL1, 2001 Viper GTS
Just keep on using whatever your using Tyler. Clean tips are what you want.
Wezbad1 is offline   Reply With Quote
Old 07-04-2013, 02:41 PM   #16
swizlstik
swizlstik's Avatar
Drives: 2018 Garnet ZL1 on order (VGXM1J)
93. Valero has it with no ethanol here.
swizlstik is offline   Reply With Quote
Old 07-04-2013, 03:01 PM   #17
Icemanmanf
Drives: 2013 Camaro ZL1
I use PetroCanada 94 as well, and don't have much black soot in the tail pipes, either.
Good to know that Chevron sells 94 in British Columbia, as I'll be taking my ZL1 there in August.
Manf
Icemanmanf is offline   Reply With Quote
Old 07-04-2013, 04:02 PM   #18
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
93 here even though there is only one station that sells it in this whole dang area the rest are 91.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 07-04-2013, 04:15 PM   #19
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
94 Petro Canada with Torco additive
tpower is offline   Reply With Quote
Old 07-04-2013, 04:55 PM   #20
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
95, made with 91 and 15 oz of Torco. In CA. Running 5% over and CAI.
Skylane765 is offline   Reply With Quote
Old 07-04-2013, 05:13 PM   #21
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 13 ZL1, 15 Scat Pack,& 15 Silverado
Shell 91 octane
2013 M6 ZL1.. Mods- Roto-Fab CF Intake, Ported and Polish LS7 TB and Snout, 2.55" Upper Pulley, 100mm Idler Pulley, Solid Isolator, Afco Heat Exchanger with fans, ID850 fuel injectors, SW 2" LT Headers With High Flow Cats, and CMS 91 Octane tune.. 579.8rwhp and 537.4rwtq
TripleBlkZL1 is offline   Reply With Quote
Old 07-04-2013, 05:31 PM   #22
Towerboat
Towerboat's Avatar
Drives: 2012 RS - 2013 ZL1
There is one station in my area that has ethanol free fuel, should I be using
That as much as possible???
Towerboat is offline   Reply With Quote
Old 07-04-2013, 08:46 PM   #23
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
93 is the highest we have at most pumps. depending if your exhaust fuse is in or out changes which tailpipes get sooted
joes407 is offline   Reply With Quote
Old 07-06-2013, 06:36 PM   #24
Tyler H
XLR8TNG
So I can assume that there is absolutely no problem running 91. The book says 91 recommended but 93 for best performance. Easy to find 94 in Calgary at Petro Canada (Sunoco for the American peeps) but I travel to Radium Hot Springs, British Columbia a lot and there is nothing out there with an octane rating above 91. I can make it there and back on a tank now but after break in I'm not so sure. I may have to put in some fuel there at some point. Hence the thread I made to ask everyone what issues if any they have encountered by using 91 octane premium. There is an Esso and a Petro Canada there. Those are my choices. Both stations are "Top Tier" approved so maybe I'm worried for nothing. I want nothing but the best for this car. My bud has a 2013 GT500 who has ran 91 octane in since new. His book also stats that 91 octane fuel is fine but for best performance us 93 or higher. I had him try the Petro Ultra94. His feedback was that the car ran great but the fuel economy dropped quite noticeably. I thought higher octane would provide best performance and best economy. I thought it would be the other way around but apparently the economy was better for him on 91. The fuel economy monitors is quite accurate I assume so I believe him. Neither of us care about fuel economy but it's nice to know what's happening. He did report no soot in his pipes while on the 94 also.
Tyler H is offline   Reply With Quote
Old 07-06-2013, 09:28 PM   #25
2012-1822
2012-1822's Avatar
Drives: Black ZL1
93 always, Chevron is my preference followed by Shell, Texaco. After that I just don't buy gas.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 07-06-2013, 09:38 PM   #26
on3fastss
on3fastss's Avatar
Drives: 2010 Camaro SS\RS
I found a shall that offered racing fuel! Is it safe to use in a SC SS?
BTW im located in nor cali..
Sent from my DROID RAZR using Tapatalk 2
on3fastss is offline   Reply With Quote
Old 07-06-2013, 11:59 PM   #27
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
93 Here near Savannah GA, I usually fill at a Kroger Gas Station but wherever I fill I always make sure that their filling tanks inlets are raised up enough that they don't get water in them when it rains.
Life is too short to drive cars that suck.
My build Thread
In or around Savannah GA on the first Sunday of the month? Come meet with us here around 11 am!
mmarx82 is offline   Reply With Quote
Old 07-07-2013, 01:42 AM   #28
jashobbsie
Davenport Stage 5+
jashobbsie's Avatar
Drives: Camaro ZL1 & C7 Corvette 3LT Z51
91...i can get 93 but don't care to right now....
jashobbsie is offline   Reply With Quote
