JDP Motorsports
Old 07-04-2013, 10:14 AM   #1
Rallycamaro2010
Rallycamaro2010's Avatar
Drives: 2010/2LT
my 3rd brake light is really dim now? need help think its going out
Its barely visible when i press on brake, the regular brake lights are brighf but the 3rd brake light in rear windshield looks like bulbs are bad? Is it a led thats in their or just bulbs and how hard is it to change
Rallycamaro2010 is offline   Reply With Quote
Old 07-04-2013, 10:25 AM   #2
RedDevil11
Drives: 2011 2LT & 2011 2SS
If you're still under warranty let the dealer handle that
RedDevil11 is offline   Reply With Quote
Old 07-04-2013, 10:35 AM   #3
Rallycamaro2010
Drives: 2010/2LT
I have 3rd party warranty $200 deductible, i have rear tint but its only 35% so it should be way brighter than this
Old 07-04-2013, 12:08 PM   #4
Rallycamaro2010
Drives: 2010/2LT
What do you guys think is wrong? Bad led
Old 07-04-2013, 02:23 PM   #5
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Could be, although I rarely see entire strips of LEDs go bad, it's not unusual to see an LED go dim before it completely fails. What I'm saying is this is not a single LED, it is a strip with multiple LEDs on it.
So, your whole strip is dim, could be an easy fix, grounding problem maybe or corroded connection. You need to get your multimeter out and make sure it has the proper voltage going to it and it has a good ground.
LED do not require very much current to illuminate, but they must have the full voltage required or they will be dimmer just like a regular bulb. In this case it's 12 volts.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 07-04-2013, 03:30 PM   #6
Rallycamaro2010
Drives: 2010/2LT
Thanks fof replying ill take it to dealer tomm see whats up
Old 07-04-2013, 04:03 PM   #7
two_wheel_mayhem
The lamp assembly is 86 dollars MSRP and you would probably have to remove a bunch of panels to track down the wiring to diagnose it. So you may be better off just paying the 200.
Old 07-29-2013, 12:56 PM   #8
sliver
sliver's Avatar
Drives: 2012 2lt rs
mine is doing the same thing .... what did it turn out to be?
sliver is offline   Reply With Quote
Old 07-30-2013, 10:18 PM   #9
Rallycamaro2010
Drives: 2010/2LT
Mine started working again for some reason
Old 07-31-2013, 07:37 AM   #10
Moorepheus
Drives: 2013 Dodge Charge R/T Plus AWD
SHORT
Moorepheus is offline   Reply With Quote
Old 01-02-2014, 07:20 AM   #11
Jalberdi99
Jalberdi99's Avatar
Drives: 2014 Summit White 2SS/RS M6
mine is doing this now, when i first start the car and press on the break everything is fine, but after like 5 minutes it dimms. im planing on taking it to the dealer and see whats the deal is.
Jalberdi99 is offline   Reply With Quote
Old 01-02-2014, 07:53 AM   #12
firedrop
Drives: 2012 2ss/l99 a6, victory red
if it were a short it wouldn't work at all, moo.
2012 2ss l99/a6
CAI, custom catback with flowmaster series 10s
firedrop is offline   Reply With Quote
Old 01-02-2014, 08:00 AM   #13
wayne watson
wayne watson's Avatar
Drives: 2014 camaro ss ,1967 chevelle ss,
Probably not check brake switch we have simaliar problem sometimes at acura
wayne watson is offline   Reply With Quote
Old 01-03-2014, 08:01 AM   #14
CrtRS13
CrtRS13's Avatar
Drives: 2013 Crystal Red Tint 2LT RS
I had the same problem, It would dim and then get bright and dim again.
The dealer did not find any shorts or bad connections. They replaced it with a new one and I haven't had any problems since.
2013 Crystal Red 2LT/RS - Gm ambient lighting kit
CrtRS13 is online now   Reply With Quote
