BORLA
Old 07-04-2013, 08:29 PM   #1
trclee
trclee's Avatar
Drives: 2011 SS LS3
Going for the cam upgrade
I just made an appointment with Vengeance Racing to have their Kaotik cam package installed and tuned(very excited) I still have a few weeks til the install and wanted to get opinions of this package
Vengeance Racing Custom Camshaft-Kaotik
Vengeance Racing 5/16th 7.400 Hardened Pushrods
Vengeance Racin .660 Lift Dual Spring Kit with Ti Retainers
Comp Trunion Kit for Stock Rockers
Melling Hi Volume Oil Pump for LS Engines
Katech C5R Timing Chain
LS7 Timing Gear
LS2 Dogbone Timing Damper
ARP Cam Bolts
GM Crank Bolt
GM Front Cover Seal
GM Front Cover Gasket
GM Waterpump Gaskets
1 Royal Purple HPS/AC Delco Filter/Dexcool Coolant
9 Complete/Professional Installation of all items listed
Custom Tuning offered by VENGEANCE PCM LLC. Price
includes 12 months free updates on existing
combination(Excluding dyno time).
is there anything else i may be forgetting that would be a smart investment at time of install or any questions i should ask them
trclee is offline   Reply With Quote
Old 07-04-2013, 08:34 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
You have a GOOD TUNER
EXcellent shop!
Excellent parts!
Your golden! Your in good hands. Believe it! Keep us posted.
Old 07-04-2013, 08:37 PM   #3
trclee
trclee's Avatar
Drives: 2011 SS LS3
I should have mentioned the only modification so far is kooks long tubes with hi flow cats and magnaflow cat back
Old 07-04-2013, 08:39 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Get a vararam or CAI.
Old 07-04-2013, 08:42 PM   #5
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Looks like everything is covered! Your in good hands! Keep us posted!
csjcsj is offline   Reply With Quote
Old 07-04-2013, 08:49 PM   #6
trclee
trclee's Avatar
Drives: 2011 SS LS3
I have been thinking about the vararam or cai but my next upgrade (hopefully)in the next 12 months will be a Whipple install. so can i still use the vararam after that or will i be buying a new one?
Old 07-04-2013, 08:51 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
You won't be able to use either. Might as well get a rotofab iirc you can use those or a pipe replacement. Not sure. Check their website.
Old 07-05-2013, 10:12 AM   #8
old motorhead
Drives: Maggie blown LS3 vette
If you know you're going f/i in the future, why not add a cam that's a little more blower friendly?
old motorhead is offline   Reply With Quote
Old 07-05-2013, 11:51 AM   #9
the_fast_one
the_fast_one's Avatar
Drives: 2012 IOM 2SS, 05 SOM Colorado
Thats what I did. Saves you extra money when you decide you need a blower cam and have to get it all replaced. Im hoping to have mine in end of July beginning of August
Let the modding begin
466/436 - JRE Rough Idle blower cam, BTR push rods, PRC 6.75 springs, halltech CAI, K&N filter, SLP 25% UD pulley, Manley H/V oil pump, Kooks 1 7/8 headers w/o cats, ported TB, Npp exhaust. BMR 1.4"/1" drop springs, ZL1 Swaybars, 1LE strut tower brace, zl1 rockers, zl1 style splitter, night shades ns3 stripe kit.
Future mods
Dss 1000hp axels Dss aluminum driveshaft, bmr full bushings, ? Clutch, ? Supercharger, wheels/drag radials.
the_fast_one is offline   Reply With Quote
Old 07-05-2013, 03:38 PM   #10
trclee
trclee's Avatar
Drives: 2011 SS LS3
I asked the same question and was told that cam was built with the whipple in mind. If that info is not correct let me know
Old 07-05-2013, 04:05 PM   #11
csjcsj
csjcsj's Avatar
It works good with a whipple! I guy on here skip1718 or something like that, has the same setup!!! You'll be fine!
Old 07-05-2013, 05:48 PM   #12
trclee
trclee's Avatar
Drives: 2011 SS LS3
Thanks for the input. I just want to get it right the first time
Old 07-05-2013, 09:48 PM   #13
old motorhead
An n/a cam that is capable of supporting 500 rwhp will have issues that a mild blower cam capable of 700 rwhp with boost won't have. With 10psi, you can get by with a very civilized cam and still make big power. If you like a little surge, buck, and shake, go for it. A big ole rumpy n/a cam can make big power with boost. Just know that a well designed blower cam can make just as much power and still have perfect manners.
Old 07-05-2013, 10:53 PM   #14
trclee
trclee's Avatar
Drives: 2011 SS LS3
What kind of issues?
