Cold Air Inductions
Old 07-04-2013, 08:31 PM   #1
feo_gang
Drives: black 93 camaro z28 coupe
1993 Z28 shuts off when hot
I Just Got My First Car a 93 Camaro z28 , it can crank and drive it but when it gets hot it shuts off , can anyone help me with this problem ??
feo_gang is offline   Reply With Quote
Old 07-15-2013, 11:45 PM   #2
Trivera
Trivera's Avatar
Drives: 2012 Camaro 2LT
Might want to check ur engine control module
2012 camaro 2LT, cherry bomb axel back exhaust, CAI
Trivera is offline   Reply With Quote
Old 07-16-2013, 10:28 AM   #3
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Aka: heat soak.....need to determine root-cause.
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 07-16-2013, 09:19 PM   #4
feo_gang
did .... think it's opti
Old 07-16-2013, 09:39 PM   #5
Trivera
Trivera's Avatar
Good luck on changing the opti did mine twice it was a bitch
Old 07-17-2013, 09:17 PM   #6
feo_gang
What's So Bad About It
Old 08-17-2013, 01:28 PM   #7
dreeve
dreeve's Avatar
Drives: 1993 lt1 z28
get a new temperature control sensor. its shutting itself off so you don't blow it up, had the same problem its like a $20 part and you can do it yourself in 5 minutes
1993 lt1 z28,BBK 52mm throttle body,accel 30lb injectors,edelbrock intake,port/polished heads,1.6 rockers,erson 222in/226ex .480 lift cam,Dougs shorty headers,pcmforless chip,RK Sport competition intake , monster transmission, 3.73's, bmr suspension
[IMG][/IMG]
dreeve is offline   Reply With Quote
