Old 07-04-2013, 09:24 PM   #1
jake2212
jake2212's Avatar
Drives: 2010 camaro 1ss/rs A6 Supercharged
Hankook ventus v12 vs Nitto invos
I have narrowed my next set f tires down to these two options. Which would you pick?
Check out my build thread: Project Ultimate Street Camaro
http://www.camaro5.com/forums/showthread.php?t=378443
jake2212 is offline   Reply With Quote
Old 07-04-2013, 09:57 PM   #2
spyderbuddy
spyderbuddy's Avatar
I went with The Nitto Invos, Love them, Better in the wet.
Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, Vararam Cold Air Intake, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Old 07-04-2013, 11:14 PM   #3
sangerbanger58
sangerbanger58's Avatar
Drives: 2010 IBM Camaro 1LT/RS
I'm getting invos in a few days
CVC Fresno
sangerbanger58 is offline   Reply With Quote
Old 07-05-2013, 03:07 AM   #4
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Love my Hankooks, but I'm biased.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan coil overs, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Dynamat, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 07-07-2013, 07:22 PM   #5
rocketrider807
rocketrider807's Avatar
Drives: 2010 Camaro 2SS
Running Hankooks right now, they're pretty good. If you're running street/back roads (maybe even autocross?) they'll be good. If you're running track (often) you might consider others (though I haven't ran said "others"). I chunked mine at the track; the fronts chunked because I understeered like an idiot. The rears chunked just a little from stress/heat, no drifts or lock ups. On the bright side, they do tell you when you've over heated them. I could feel grip fall off if I pushed too hard.
PIN IT TO WIN IT!
rocketrider807 is offline   Reply With Quote
Old 07-07-2013, 07:53 PM   #6
Denis
Denis's Avatar
Drives: 2010 SS
I run Invo's. I love em. No issues at all. Just stay off the strip with em...terrible wheel spin. But for daily driving and even auto cross I have zero complaints.
