BeckyD @ James Martin Chevy
Old 07-04-2013, 09:54 PM   #1
MikeMoach
MikeMoach's Avatar
Drives: 2010 RJT 2SS/RS
1LE rims put grove in a brake line?
I'm not sure what this line is but pretty sure it's the brake line on my rear tires, I recently put on my 10 spoke rims and when I drive I heard the line clipping the wheel balances and it left a grove in the line
It's only on both rear tires and I'm lowered 1"
I will post pics tomorrow, it's not the line that clips to the top of the toe rod, if your looking at the side of the car it's closer to the front of the rear wheel well, it's has a black rubber insulator and the grove is like a stainless hose inside it
For now I zip tied it to my toe rod so I can drive without damaging it more
What I'm trying to get at is how can I fix it? Can I simply cut and splice that line? Or do I have to replace the whole thing? Also how and where do I get the material to fix it?
Edit: pics in post #8
MikeMoach is offline   Reply With Quote
Old 07-04-2013, 10:13 PM   #2
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
E brake cable?
Me too,I used zip ties.
rockrau is offline   Reply With Quote
Old 07-04-2013, 10:29 PM   #3
MikeMoach
MikeMoach's Avatar
I didn't have time to try but can I move that clip that holds the line into the cradle? And shorten the loop that touches the rim
Old 07-05-2013, 12:09 AM   #4
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
It's the e-brake cable. I pushed as much slack out of mine as possible and put a small hose clamp behind the bracket.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 07-05-2013, 06:24 AM   #5
MikeMoach
MikeMoach's Avatar
Ok I'll try that when I get home today, but what about the grove in the cable?
Like I said I'll post pics today but should I have it fixed?
Old 07-05-2013, 05:59 PM   #6
rockrau
rockrau's Avatar
For the nick, liquid electrical tape?
Old 07-05-2013, 06:29 PM   #7
MikeMoach
MikeMoach's Avatar
Liquid electrical tape? How does it work and where can I get it?
Old 07-05-2013, 07:13 PM   #8
MikeMoach
MikeMoach's Avatar
here are the pics i finally got to get them uploaded
i looked up that liquid electrical tape, do you think it will work in my situation? or is this too deep of a grove?
Old 07-06-2013, 01:26 AM   #9
SSMickey
SECC
SSMickey's Avatar
As long as the groove is not through the metal housing, you'll be fine. Just seal up the groove to prevent corrosion of the cable housing.
Old 07-06-2013, 07:16 AM   #10
MikeMoach
MikeMoach's Avatar
I haven't used the car in 3 days and I haven't seen anything leaking so I'm guessing it didn't get through, but just for my own knowledge does anyone know what the inside diameter is in that line?
Ill go to Loews and Home Depot today to look for the liquid electrical tape, I just wanna make sure that its waterproof before I get it
Old 07-06-2013, 07:22 AM   #11
bkdamon
bkdamon's Avatar
Drives: Rally Yellow 2012 1LT
It's not going to leak. It has a wire inside.
bkdamon is offline   Reply With Quote
Old 07-06-2013, 07:34 AM   #12
MikeMoach
MikeMoach's Avatar
Oh ok I didn't know that thank you, do you know how thick the wire inside is? So I can just have peace of mind and know what I'm covering up isn't more then what it is
Old 07-06-2013, 07:57 AM   #13
bkdamon
bkdamon's Avatar
I don't know the size but's it's a fairly thick cable and the nick in the exterior doesn't look to have compromised it. As you may know, It's part of the emergency/parking brake system you manually activate when you pull up the lever in your center console. It's not part of the hydraulic system. As was mentioned you can get some liquid electrical tape from a hardware store like Lowes to keep it from rusting and developing problems in the future. You may never use it unless you have a manual transmission but when/if you do need it you won't want the it to snap because moisture caused it to rust and weakened it.
Old 07-06-2013, 08:22 AM   #14
MikeMoach
MikeMoach's Avatar
I didn't know they were seperate thank you, I have an auto and I don't use it much but I'm worried that one time I will need it and I pull it and I snap the cable
I'm guessing the wire inside is a braided cable? And I think you're right I didn't get through the exterior of the cable
