B&M Racing
Old 07-06-2013, 11:59 AM   #15
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
Cable construction; inner cable, outer cable,outer cover(wether protection).Liquid tape(Lowes) to seal the cut from the weather.
rockrau is offline   Reply With Quote
Old 07-06-2013, 12:21 PM   #16
MikeMoach
MikeMoach's Avatar
Drives: 2010 RJT 2SS/RS
Thanks I just got the liquid tape and ill put it on later tonight so it doesn't bake in the sun all day and not dry
MikeMoach is offline   Reply With Quote
Old 07-06-2013, 12:43 PM   #17
ToolFan66
ToolFan66's Avatar
Drives: 2011 2SS 6.2L W/RS package
You can drive the car, your not going to hurt anything, you would have to be driving in water to get it soaked enough to even get water inside the cable.
KooKs LT Headers, Borla S-Type cat back, RotoFab CAI, Bo White PTB, RMCR tune...
ToolFan66 is offline   Reply With Quote
Old 07-06-2013, 01:39 PM   #18
MikeMoach
MikeMoach's Avatar
Yea we've had really nice weather these past couple days so it hasn't seen water at all, like I said once the sun passes its peak ill go and put the liquid tape on, and hope that all is well
Old 07-06-2013, 11:30 PM   #19
MikeMoach
MikeMoach's Avatar
I put on 2 coats of the liquid tape, I covered it really well, is that all there is to it?
I left it zip tied for now, can I move the clip that was holding it before? Or should I go with the hose clamp?
Old 07-06-2013, 11:46 PM   #20
BLACK67
Drives: 2010 Camaro 2SS/RS CGM
Send a message via MSN to BLACK67
Originally Posted by SSMickey View Post
It's the e-brake cable. I pushed as much slack out of mine as possible and put a small hose clamp behind the bracket.
Did this exact fix to mine today.
SPi Performance Stage 3 package Comp Cam
PHADT FE4 ZL Stg.3
VMAX CNC Spiral Ported Throttle Body
Dynatech LT headers, Hi flow Cats
MBRP 3" 304 stainless X-pipe exhaust
Fastlane true CAI.
Barton shifter
BLACK67 is offline   Reply With Quote
Old 07-06-2013, 11:55 PM   #21
MikeMoach
MikeMoach's Avatar
Then that's what I'll do tomorrow, I'm sure I got 2 hose clamps in the tool bag somewhere no matter the size ill jus cut the slack off to fit
Thanks for all the help and info guys I appreciate it
Old 07-08-2013, 07:46 AM   #22
Oliv59
Oliv59's Avatar
Drives: 45th M6
Please post a picture after the fix
Oliv59 is offline   Reply With Quote
Old 07-08-2013, 01:08 PM   #23
MikeMoach
MikeMoach's Avatar
No problem ill post it when I get home
What I did was use the yellow clip that is on the cable that held it into its seat and put a hose clamp around that and the toe rod
Ill get the pics up as soon as I can get to my computer
Old 07-08-2013, 02:14 PM   #24
MikeMoach
MikeMoach's Avatar
ok heres the pic, sorry if its too large and too close, its the best i could do with no jack and the wheel on
i believe the clamp was 2-1/2" or 3"
i opened the clamp, snaked it between the ABS and the toe rod and around the cable and tighten up
Old 07-08-2013, 05:03 PM   #25
rockrau
rockrau's Avatar
I'm using factory mount and a zip tie.E brake is smooth.
Old 07-08-2013, 05:08 PM   #26
MikeMoach
MikeMoach's Avatar
Would you mind taking a pic?
Old 07-08-2013, 06:17 PM   #27
rockrau
rockrau's Avatar
Pictures
Pictures are attached to this post
Old 07-08-2013, 06:21 PM   #28
MikeMoach
MikeMoach's Avatar
I see what you did, you clipped it in then zipped it to the trailing arm
Have you used your e-brake since doing that?
