Old 07-05-2013, 03:34 AM   #1
zcorvette04
zcorvette04's Avatar
Drives: 2012 Chevrolet Camaro 2SS/RS
Halo issues
Alright I have the AAC fog addition kit for my LS. I also have eagle eye HID with halos. When I hook the halos up my driver dude halo and fog work sometimes but most if the time do not. Passenger works fine. Connections are all good as checked by mechanic. Any ideas? I was told replace the fuse but don't know what fuse and if they work sometimes is it the fuse?
zcorvette04 is offline   Reply With Quote
Old 07-05-2013, 06:41 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Do they flicker on/off or is it just sometimes they work and sometimes they don't? Either or, if it was a blown fuse then they wouldn't work at all.
Click to view my build thread
Old 07-05-2013, 11:22 AM   #3
zcorvette04
That's what I thought. No flicker they either work or they dont. And right now it's just not working at all.
Old 07-10-2013, 05:08 AM   #4
zcorvette04
Any ideas?
Old 07-10-2013, 06:30 AM   #5
The Stig
The Stig's Avatar
Have you checked the connections with a multi-reader?
When does it cut on/off? Is it while you're driving?
Old 07-10-2013, 08:45 AM   #6
Wraithier
Drives: 2013 Camaro 1LT
Did you install a relay for the Eagle Eye halos? I have the CCFL Eagle Eye halos and originally had them wired directly into my parking lights, they would draw too much power and the driver side would go out, then eventually the passenger side would follow.
Here is my post:
http://www.camaro5.com/forums/showth...ighlight=Relay
Wraithier is offline   Reply With Quote
Old 07-10-2013, 08:58 AM   #7
AKA-22
AKA-22's Avatar
Drives: ELLE-1
when you said ACC i thought to myself , "oh boy here we go again"!!
AKA-22 is offline   Reply With Quote
Old 07-10-2013, 09:16 AM   #8
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
The Eagle Eyes lights use a CCFL inverter (box located on the back of the housing) to convert the current from 12VDC to a usable level for the CCFL rings. You need to be sure to check your connection to this box as well as the connection from the box to the ring. If the connections are good the CCFL inverter may be bad. You can contact whoever you bought the EE lights from to see if they can offer a replacement. Hope that helps.
www.AACstyle.com
AACstyle is offline   Reply With Quote
Old 07-10-2013, 09:39 AM   #9
SgtPickles69
Team LFX
SgtPickles69's Avatar
Drives: Fast
^ This. If that doesn't work then like Wraithier said, this MIGHT be your problem which can be fixed by doing this.
EDIT: How are your halos wired?
SgtPickles69 is offline   Reply With Quote
Old 07-10-2013, 03:14 PM   #10
zcorvette04
They are wired straight I tony park lights when I get back stateside I will try the above fix^^
