Elite Engineering
Old 07-05-2013, 07:57 AM   #1
Steve RS/SS
Steve RS/SS's Avatar
Drives: 2010 2SS/RS
Slp Headers
I just purchased SLP long tube 1 3/4 headers with high flow cats and was just trying to clear something up. Some people have said they did not get a CEL and other said they did. Is a tune required or can you drive the car with a CEL with no issues and is there anything else that has to be done because of the header install? I appreciate the input. WIth all this computer stuff on these cars I want to make sure I do this the right way.
Steve RS/SS is offline   Reply With Quote
Old 07-05-2013, 08:05 AM   #2
HorsemenLC-SS
Drives: 2010 Camaro SS, 2005 CTS-V
Hit and miss. The rear o2 sensors tell the pcm that the cats are working or not working. With high flows you still might get the light. I think they say the only high flows that wont throw the cel are the green high flows from kooks. Other than that you'll have to tune em out. And you can run your car with that cel on itll probably use more fuel tho.
HorsemenLC-SS is offline   Reply With Quote
Old 07-05-2013, 08:54 AM   #3
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
You can run the car as long as you want without the tune. The rear o2s do not change the performance of the car, they just check to make sure that the cats are working.
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 07-05-2013, 08:56 AM   #4
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
^^^^This....and it won't hurt running this way. Most end up getting a tune anyway though because they don't want to keep looking at the CEL and want to get the most out of the header install.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 07-05-2013, 11:31 AM   #5
Dynamite
Dynamite's Avatar
Drives: 2013 Camaro 2SS/RS XD
Yep that's right.
Dynamite is offline   Reply With Quote
Old 07-05-2013, 04:03 PM   #6
Steve RS/SS
Drives: 2010 2SS/RS
thanks guys I appreciate the responses. It put my mind at ease.
Old 07-05-2013, 04:12 PM   #7
BlaqWhole
BlaqWhole's Avatar
Drives: 2017 Camaro ZL1 A10
I wouldn't dare do any modification that would cause a CEL without the necessary ECU tuning. Regardless of what the CEL is, I'd say get it tuned. Because the CEL could be trying to alert you to some other problem that you may not be aware of. You spent hundreds of dollars on the headers, spend another couple hundred and get it tuned correctly.
2017 Camaro ZL-1 A10 - Roto-Fab cai - Katech ported TB - MBRP Race catback!!
2017 Challenger Hellcat M6!!
Saving the world...1 hp at a time!!
BlaqWhole is offline   Reply With Quote
Old 07-05-2013, 06:33 PM   #8
RJT-SS
RJT-SS's Avatar
^^^^^Good point.
Performance Mods:
Old 07-05-2013, 08:54 PM   #9
96MrBass
96MrBass's Avatar
Drives: GM
I have a full SLP exhaust installed and after the tune it was a totally different car.
I am still have a cel with no problems its just a pain seeing it.
Roto- Fab Cai, SLP 1 3/4" headers, 3"X pipe, LM2 cat back, Comp Cam & AI Heads, SLP UP, RPM Tuned, GPI Intake, Vmax TB, ADM Air Scoop, 3.91 Gears, Gforce driveshaft, Braille 21#, Elite Catch Can, Pfadt Tie Rods, Diff Bushings and Trailing arms, Eibach spings & sways, BMR cradle bushings, Nt555r's.
96MrBass is offline   Reply With Quote
Old 07-05-2013, 09:56 PM   #10
kc ss/rs
kc ss/rs's Avatar
Drives: 2010 ss/rs
performance gains are advertised on their website with vehicle untuned.
kc ss/rs is offline   Reply With Quote
Old 07-05-2013, 10:38 PM   #11
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Was the RPM tune suppose to include the LT's? If so, you need to get back with them about that. They should have turned the rear O2 sensors off with the tune. Are you sure it's the cat efficiency codes?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-06-2013, 07:24 AM   #12
Steve RS/SS
Drives: 2010 2SS/RS
point taken...
Old 07-06-2013, 08:14 AM   #13
Steve RS/SS
Drives: 2010 2SS/RS
If I decide to do the tune is the handheld tuners I see advertised the best way to go? I would only be looking to turn off the CEL.. I dont run the car at the track or abuse it.
Old 07-06-2013, 09:52 AM   #14
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
I can Help
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
