Old 07-05-2013, 04:32 PM   #1
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
What air pressure for a road course track day?
I have Nitto Invo's 275/315's and was wondering if anyone knows how well they will perform and what is the recommended air pressure to set them to for a road course track day?
Not a Camaro but it works for now!
Old 07-05-2013, 04:35 PM   #2
SPCBA
Drives: pleather and Chiclets
it really is a trial and error thing. basically you need to figure out what temp and pressure you want to leave the track on and adjust accordingly due to air conditions and track conditions and your driving
i adjust after every session.
SPCBA is offline   Reply With Quote
Old 07-05-2013, 11:12 PM   #3
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 07-06-2013, 08:54 AM   #4
ssmike
Missing Big Red
ssmike's Avatar
I would imagine that as they heat up the pressure goes up. What is the max that they will go safely? Is there an optimum high temp to run at or is that also something that depends on many factors? Thanks!
Old 07-06-2013, 04:56 PM   #5
TBone
TBone's Avatar
Are you trying to prepare for the 19th? IF so wait till you get there, find me and I will explain it then. There are soooo many factors but I will get you set straight, or twisty depending on your point of view.
Your coaches will also mention this, at least they should, in your classroom that day.
Just remember your tire gauge that day.
T.
Track fix.
Old 07-06-2013, 07:13 PM   #6
ssmike
Missing Big Red
ssmike's Avatar
T.
That sounds good T.! Thanks!
