Old 07-05-2013, 08:34 PM   #1
jake2212
jake2212's Avatar
Drives: 2010 camaro 1ss/rs A6 Supercharged
Zl1 wheels question
Will the 20x10 wheels fit in the rear as well?
Check out my build thread: Project Ultimate Street Camaro
http://www.camaro5.com/forums/showthread.php?t=378443
jake2212 is offline   Reply With Quote
Old 07-05-2013, 08:52 PM   #2
NinoSS
Drives: 2SS/RS CGM LS3
No... A +23 in the rear will stick out bad. You can get the Factory Reproduction ZL1's in 20x10 +35 that will work.
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 07-05-2013, 10:00 PM   #3
jake2212
jake2212's Avatar
How bad will it stick out in the rear?
Old 07-05-2013, 11:31 PM   #4
oldfriend
Drives: Fiat 500 E
Withe a strait edge at the center off the wheel it will be about 5/16 to 3/8 pass the outer fender , but it will look more than that visually
Old 07-06-2013, 12:08 AM   #5
jake2212
jake2212's Avatar
Damn. I don't want to get the factory repros and I'm getting a great deal on these 4 front wheels
Old 07-06-2013, 01:19 AM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
I'd say try them out and see 1st before you buy. You could always sell the other 2 just a thought.
10.45 @ 130mph all motor
GPI everythang!
Aka MR. NightFury Killer
62nalide is offline   Reply With Quote
Old 07-06-2013, 01:19 PM   #7
jake2212
jake2212's Avatar
okay. that being said is sticking out a little the only problem? i.e. will fit with the rotors and cables fine
Old 07-06-2013, 10:00 PM   #8
oldfriend
Drives: Fiat 500 E
It should clear all of that
But again , if you go to a delar that has a ZL1 on the lot , take a look at the rears , the wheels do stick out just about 3/8 pass the fender , if you stick a strait edge , you will see exactly what we are talking about
