Cold Air Inductions
Old 07-06-2013, 12:44 AM   #1
Black Beast
Black Beast's Avatar
Drives: 2010 Camaro 2SS LS3
ZL1 Strut Tower brace install, HELP!
what modifications are required for a zl1 strut tower brace to fit a 2010 camaro ss ls3? I have a brace on the way and trying to get an idea of what needs done before it gets here. Also i have an aftermarket hood that will provide plenty of clearance.
2010 Camaro 2SS, 2.9L Whipple S/C, 1 7/8 Kooks headers high flow cats, 3" kooks exhaust, ARP head bolts, GX9 Cam, ZL1 fuel pump w ADM pump module, Fuel Rail, 63 lb injectors, Lifters, Springs, Rx catch can, ZR1 Clutch & Flywheel, K&N intake, Dyno tuned 708RWHP
Black Beast is offline   Reply With Quote
Old 07-06-2013, 12:54 AM   #2
SemperGumby
I'll probably offend you
SemperGumby's Avatar
Drives: 2013 2SS/RS M6
Pretty sure you're looking for this: http://www.tpis.com/parts/view/267
SemperGumby is offline   Reply With Quote
Old 07-06-2013, 01:04 AM   #3
Black Beast
That's what i wasn't sure of. If i'd need the shim kit or be able to just drill the holes and bolt it on.......
Old 07-06-2013, 01:27 AM   #4
SemperGumby
Gonna be honest, after looking through some of the threads it would seem that you don't need shims. I'd wait for someone with the ZL1 brace to chime in, I ordered the BMR one.
Old 07-06-2013, 01:39 AM   #5
Black Beast
That's kinda where i'm at. Thanks for your input though
Old 07-06-2013, 02:55 PM   #6
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
You got the zl hood? Won't fit without it
jeremywes is offline   Reply With Quote
Old 07-06-2013, 04:16 PM   #7
Black Beast
nope, but I have a hood that will provide plenty of clearance.
Old 07-07-2013, 12:20 AM   #8
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
The ZL1/1LE/convertible strut tower brace WILL NOT fit on 2010 (and early 2011) Camaros. GM changed the design of the strut tower during the middle of the 2011 model year.
The adapter kit posted above will allow you to install a GM strut tower brace on your 2010 but I would get an aftermarket brace instead. There are plenty of aftermarket companies that offer a brace specifically for the 2010 Camaros. I've seen pictures of a GM brace installed on 2010's using the adapter kit and it looks funny (just my opinion). Since you have a supercharger, I'd get the Hotchkis brace. It is designed to clear superchargers.
Sorry for the bad news but you should sell the GM brace and get an aftermarket brace instead.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
