Old 07-06-2013, 01:27 AM   #1
ajax.
ajax.'s Avatar
Drives: 12SS,12SRT8,14COPO,77Vette
Improving 60' Times
Been running at the track and I'm always running 12.74 @ 109. Tonight I went down to the track and was posting absurd numbers with my best of only a 12.91.. I even had a bunch of 13 second passes...real embarrassing...
My 60' is usually 1.9-2.0 so my question is what's the best way to practice to get a good 60' time? Any special techniques?
My method is tires down to 15-16 psi...then water box and heat the tires up real good and get them nice and hot. Then I brake stand and launch at 1000 rpm or so with traction control completely off. Everyone tells me I have A low 12 second car but honestly i think that's impossible. Tired of getting smoked by every car at the track...
ajax. is offline   Reply With Quote
Old 07-06-2013, 01:58 AM   #2
Ice Demon
Ice Demon's Avatar
Drives: 2010 Camaro SS
It probably has to do with the hot and humid summer weather. Do you know what the DA was? I also run NT05R's but I usually run around 20psi in them. I have never ran them that low. As far as improving your 60ft time a stall is the best way.
Mods: "Cam Only"
Ice Demon is offline   Reply With Quote
Old 07-06-2013, 02:27 AM   #3
Neumatic
Neumatic's Avatar
Drives: 2010 Camaro 2SS M6
60' is killing you, I can cut 1.8's on street tires with stock gears. I have a stick so I don't really have any pointers for you unfortunately, but I know there are quite a few guys on the forum that have a lot of experience racing auto's so you should be able to find someone on here that can help you getting that 60' down to where it should be.
Tuned by Back Street Performance 471hp/429tq
11.86 @ 117.47, 1.749 60'
Neumatic is offline   Reply With Quote
Old 07-06-2013, 08:46 AM   #4
ajax.
ajax.'s Avatar
DA was 1800ft I was really taking a beating. I usually run my 05Rs at 20 psi but was frustrated and tried 15/16 psi. Any auto guys that can chime in?
Old 07-06-2013, 09:17 AM   #5
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Now what size wheel are you running? If its an 18 in wheel i would say try raising the tire PSI up. I run mine aorund 18psi normally and sometimes up to 20psi after a burnout and i have pulled several low 1.7's and a 1.69 on em.
If you are on a 20 inch wheel then keep the tire pressure higher. closer to 30.
But as far as launching technique i too have a manual so i cant recommend anything but more seat time.
xjer22x is offline   Reply With Quote
Old 07-06-2013, 09:51 AM   #6
ajax.
ajax.'s Avatar
Yea I'm running a 20...been using about 15-20psi. The fronts I usually leave at 35.
Old 07-06-2013, 10:21 AM   #7
xjer22x
xjer22x's Avatar
Thing you have think about with a 20inch rim is that there is very little sidewall. So getting flex out of it is difficult. What will benefit you is actually filling the tires up with more air to get a better contact patch with the tire.
Just for giggles next time I would say no lower than 28 in the rears. I would even start at 32. Get them nice and hot with a Smokey burnout and give em a shot.
Most guys running anything under 20psi are on smaller wheels ... between 15-18 inch wheels. Due to the tall sidewall they get on the tire.
But lower profile tires wont benefit the same way.
sent from my galaxy s3. that would explain the errors.
Old 07-06-2013, 10:43 AM   #8
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
Hey do you also run the NT05R's on the street?
SNSSTR is offline   Reply With Quote
Old 07-06-2013, 11:13 AM   #9
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
try going a lil easier off the start u may be spinning. heat those tire up too. i run about 24-26 usally in mine . but im still on factory tires. but 20"s dont need low pressure like others. dont do 100mph burnouts lower speed burnouts that way the tire gets heat all the way across .
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 07-06-2013, 11:41 AM   #10
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
What's done to the car?
I went 1.92 stock tires and 1.85 on 20" NT 555Rs. Stock converter.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-06-2013, 11:48 AM   #11
Ice Demon
Ice Demon's Avatar
Yes I actually I will be running them on my car all summer long. They do ok in the rain and they hook great.
Mods: "Cam Only"
Old 07-06-2013, 02:19 PM   #12
ajax.
ajax.'s Avatar
Maybe my tire psi is the issue...I also run the 05R's on the street never gave me a problem. Makes sense though about the 20in rim I'll try running around 30-32 psi. Front's I'll leave alone at 36.
Old 07-06-2013, 05:13 PM   #13
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Are you running a stock stall converter?
Camarojt is offline   Reply With Quote
Old 07-06-2013, 05:37 PM   #14
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
When I ran my 555rs on 20" I got best results at 22 psi. Turned all the nannies off and did the burnout in paddle shift right after the water. 1st gear up to 4500-5000 rpm then shift to 2nd and tried keeping it from hitting the rev limiter. When done right the rpm would go down as the tires got stickier and rolled out of the burnout. Then I made sure I put it back in Sport
DarkCry956 is offline   Reply With Quote
