Solo Performance
Old 07-06-2013, 08:07 AM   #1
Jfoster
Drives: 2016 GT vert.
pics of 5th bow
Does anyone have pictures of what exactly breaks or the tabs that pull away on the 5th bow? Also, how do you tighten up the cable tensioners along the sides. Thanks in advance...
Also, are there in members in La that know of a dealer that is familiar with the top repairs? So far all the ones I've talked in the central to nw part the state are clueless.
We're new owners of a '11 and have noticed the 1/2" gap along the back between the top and rear deck. There's no signs of rubbing along the top, but its not tight either. With that, is there a likely hood of damage if the 5th bow isn't tight? The only issue I have as of now is the right cable tension is loose.
Jfoster is offline   Reply With Quote
Old 07-08-2013, 09:14 PM   #2
ToddB
Drives: 2011 2SS Convertible Supercharged
I just had the same thing happen to my 2011.
2011 Camaro SS, LS3,Whipple SC, 13 PSI,CAI intake, ARH 2" Headers, Corsa exhaust, ZL1 fuel pump with ADM FPCM LS9 Cam and Meth,ID850, BMR suspension upgrades,Tune by JRE
ToddB is offline   Reply With Quote
Old 07-09-2013, 06:28 PM   #3
Jfoster
So far I haven't found a dealer in my area that has worked on any tops, but did find one close by that says they had just sent a tech to gm 's convertible top class. So, its in line for repairs. Just wish I could get some step by step pics for everyones benefit.
