B&M Racing
Old 07-06-2013, 08:37 AM   #1
JEFF75645
Drives: his wife crazy buying mods
What about these wheels for drag duty
The don't look like your typical drag wheel but with the weight I cant help but give these a second look. With the 18x9.5 weighing in at 21.4 pounds and the 18x8.5" fronts coming in around 19 pounds. I thought these would be perfect. Thoughts?
http://www.konigwheels.com/Konig-Hom...heels/KILOGRAM
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 07-06-2013, 09:29 AM   #2
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Gotta be careful with the offset on them. I couldnt find those specs anywhere. But if it is the wrong offset it might not fit without spacers. which is not the best idea for racing.
I believe when my z06 replica wheels were shipped it said they were like 23-24lbs if i remember right. They area a lot lighter then stock and are known to fit.
xjer22x is offline   Reply With Quote
Old 07-06-2013, 10:50 AM   #3
JEFF75645
Front and rear offset is +35
Old 07-06-2013, 11:18 AM   #4
xjer22x
xjer22x's Avatar
Sounds like it should be ok then. Id say order the rears first and then if they fit give the fronts a shot.
EDIT: verify the bolt pattern too. From the ones i saw it didnt match up.
Old 07-06-2013, 11:45 AM   #5
JEFF75645
They are 5x120 also.
Old 07-06-2013, 12:30 PM   #6
xjer22x
xjer22x's Avatar
Sounds like a winner then.
sent from my galaxy s3. that would explain the errors.
Old 07-07-2013, 11:56 AM   #7
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
What do they cost?
Cuda7050 is offline   Reply With Quote
Old 07-07-2013, 12:11 PM   #8
JEFF75645
$216 for fronts and $226 for rears each
Old 07-07-2013, 01:37 PM   #9
grocerygetter
instigator
grocerygetter's Avatar
I run tsw nurburgring wheels in the same sizes for track days...they are lighter though.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 07-07-2013, 01:44 PM   #10
JEFF75645
What are the weights of the N'burgs?
Old 07-07-2013, 04:02 PM   #11
Juice2SS
Drives: 2011 2SS
Nurburgrings are 21 rear and 18.5 front. I run them also.
Juice2SS is offline   Reply With Quote
Old 07-07-2013, 04:23 PM   #12
JEFF75645
These are 21.4 lbs for the rear and 19.7 on fronts. Not bad for $900.00 shipped
Old 07-07-2013, 04:34 PM   #13
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
You guys better make sure there is enough mounting pad height on these to clear the Brembo calipers. Just because it has the correct bolt pattern and an offset that may work okay, doesn't necessarily mean they're going to fit!!! There needs to be enough distance from the surface of the mounting pad to the back of the spokes to clear the caliper....offset has NOTHING to do with this measurement. There is a .pdf on the Weld Website that explains it pretty good.....since they make their RT-S wheels with three different mounting pad heights.
blazzin1 is online now   Reply With Quote
Old 07-07-2013, 04:35 PM   #14
JEFF75645
If not I will send them back.
