Cold Air Inductions
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic
Old 07-06-2013, 01:48 PM   #1
palmdog
palmdog's Avatar
Drives: 2010 camaro SS
Help needed in VA beach area!
Trying to change out valve springs to complete this cam install this weekend and if anyone in the Virginia beach area has a LS valve spring compressor tool they would be my HERO!!!!! Having clearance issues with unversal spring compressor (wheel type that has two forks that capture bottom of spring). Too tall on back cylinders . The lever type won't work because of supercharger is in the way.... HELP!!!!!!!!!!! The tool I am referring to does both springs at the same time....
palmdog is offline   Reply With Quote
Old 07-06-2013, 03:56 PM   #2
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
You may get a quicker response in the regional forums
FaytalsCamaro is offline   Reply With Quote
Old 07-06-2013, 04:36 PM   #3
Neumatic
Neumatic's Avatar
Drives: 2010 Camaro 2SS M6
I had the same problem, if you have some scrap steel you can easily make your own like I did if you have some tools. Very simple and it works like a charm.
Tuned by Back Street Performance 471hp/429tq
11.86 @ 117.47, 1.749 60'
Neumatic is offline   Reply With Quote
Old 07-06-2013, 05:39 PM   #4
palmdog
palmdog's Avatar
thanks for the responses.. I went ahead and fabbed up a piece of steel... good to go for now... 4 more cyls. to go, so far no problems.....
Old 07-06-2013, 07:58 PM   #5
SS4PK
SS4PK's Avatar
Drives: 2010SS
Sorry, where at in Chesapeake? My wife and I are in great bridge. I haven't seen your car around.
Her Hot Rod.
SS4PK is offline   Reply With Quote
