ADM PERFORMANCE
Old 03-02-2008, 08:54 PM   #1
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
Z28/SS exhaust
as you know I just got a Z28 I knew everything there was to know about the 3.8L, but Im wondering whats the best exhaust setup in Y'alls opinion? Im gonna do the full exhaust so feel free to chime in!
TFord is offline   Reply With Quote
Old 03-02-2008, 10:46 PM   #2
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
I've heard great things about the Random Tech exhaust... and, of course, evryone loves the Corsa... B&B Tri-Flow is another great one... if you dont mind the noise, the GMMG chambered exhaust is the best sounding one available, IMO
stay away from the Flowmaster... I had one and it sounded good, but it was a serious performance inhibitter.
got tequila?
SilverTurtle is offline   Reply With Quote
Old 03-02-2008, 11:18 PM   #3
MTron
Drives: 99 Grand Prix
i would say check out clubgp.com If you are interested in ANYTHING 3800 series engines, it is there, granted the forum is for grand prixs, but we use the same engine, so a lot of the performance parts and exhaust stuff will be the same. AT the very least you can check out the exhast section to see vids of other members setup's so you can see what sounds best to you......but a personal FYI from someone with a 3.8, beware the dreaded DRONE with custom exhaust, i dont mind so much, but i can be troublesome at times
MTron is offline   Reply With Quote
Old 03-03-2008, 01:01 AM   #4
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Agree w/ Turtle!!! Stay away from the flowmaster!
I know...I HAD ONE. Didn't like it. Didn't do a d@mn thing to help.
Old 03-03-2008, 01:08 AM   #5
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
SilverTurtle Ive heard that GMMG chambered exhaust. It sounds great, but where do I buy?
Old 03-03-2008, 01:58 AM   #6
SilverTurtle
currently, there's a group purchase going on on LS1Tech... go to LS1Tech.com and then do a search for GMMG group purchase... I think its $650 after they get the first 10 orders or something like that... I'm considering getting in on that GP
other than that, you can go to GMMGinc.net and buy directly from GMMG
got tequila?
Old 03-03-2008, 12:37 PM   #7
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
If you're looking at just a "cat-back", then GMMG is a good choice. I'm considering it for my SS.
I changed the complete system on my SS, (see sig.) and I like the result.
Moose is offline   Reply With Quote
Old 03-03-2008, 03:45 PM   #8
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
for price, power, and sound, you cant beat a magnaflow catback.
I piss excellence
and fart awesomeness
Old 03-03-2008, 04:25 PM   #9
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I've always been partial to Gibson. But that was truck cat backs. No idea if they are as good for Camaros.
Old 03-03-2008, 04:49 PM   #10
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
I had a magnaflow on my 3.8L and I loved it! I havent heard how it sounds on the 5.7L though.
Old 03-05-2008, 10:49 AM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I think Magnaflow and SLP are great options for stainless catbacks. The SLP is available with a resonator or a muffler. The Loud Mouth SLP (resonator) will rasp really bad if you plan to run long tubes headers, so be forewarned.
I run QTP long tubes with their high velocity merge collectors(HVMC.) I used to have mid-length MACs, then switched to QTP standard collectors, and have ended at their HVMCs. They are T304 stainless, 1 3/4" primaries, and are about the longest primary tube headers on the market. I use QTPs catd' Y-pipe but have replaced their cats' with Magnaflow cats' and changed the orientation a little bit for better ground clearance. I have a Borla adjustable catback and use QTPs QTEC (electric cutout) and the only thing I'll end-up changing is eventually fabb'ing up my own T304 Y-pipe, merge collector, and four-inch I-pipe. I love the system because with the cutout closed, there is little to no rasp and with it open, you could hear it a mile away.
You'll spend close to $2000 for a set-up like this but it will last as long as the car and give you good power. I've made more than 360 rear wheel horse power with this setup with only an air box and a dyno tune. I have a stock long block and a big stall converter.
There are a bunch of other header and catback manufacturers. It will pay to do some research. If you want to listen to sound bites, try ls1sounds.com.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 03-05-2008, 11:46 AM   #12
GTAHVIT
Blessed
GTAHVIT's Avatar
I will deifinitly be consulting you when the time comes to buy my exhaust for the Maro.
Can you please define "long block"? I'm thinking this isn't the same as a crate motor long block vs short block.
Thanks
Old 03-05-2008, 01:00 PM   #13
Moose
Moderator
Moose's Avatar
If anything, adding the SLP L/T's after installing the Loudmouth only improved the sound, IMO. "rasp"????
Old 03-05-2008, 03:46 PM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thanks
I'm not expert on anything, however I'm just adicted to exhaust and information thereof
The way I referrenced long block is exactly as you are thinking.
DOUBLE EXHAUST ON V6 SILVER ONE Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 43 03-22-2011 12:52 AM
Exhaust note MTron 5th Gen Camaro SS LS LT General Discussions 10 02-01-2008 02:44 PM
Muscle car exhaust sound linkwpc 5th Gen Camaro SS LS LT General Discussions 19 12-09-2007 06:50 AM
MODIFIED EXHAUST SYSTEM BAN IN THE WORKS Kyle.Gilmour General Automotive + Other Cars Discussion 17 08-14-2007 07:43 AM
Car Law- i.e. tire size, exhaust noise Kyle.Gilmour General Automotive + Other Cars Discussion 11 08-06-2007 11:09 AM
