Jason 98 TA
Old 07-06-2013, 04:41 PM   #1
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
Spark Plug wire set?
I am trouble shooting a misfire and am going to start at my plugs and then wires. What brand wires is everyone running that has heavy mods, I know the headers and blower crate some heat but I have seen a lot of folks sticking with the stock wires, are they the best?
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 07-06-2013, 06:11 PM   #2
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
I have MSD wires. No issues so far.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 07-06-2013, 06:31 PM   #3
StreetSS
Drives: 2011 Camaro SS
My setup is similar to yours. I had misfire issues. JRE installed zr1 plugs with stock wires last week. No issues yet.
StreetSS is offline   Reply With Quote
Old 07-06-2013, 06:34 PM   #4
Turbo99
Turbo99's Avatar
I have the same and now have a misfire. I am going to call Ted Monday and send him my logs and ask what he thinks.
Old 07-06-2013, 07:15 PM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I wouldn't say the best, more like it hasn't been proven that there is any difference between stock wires and the leading aftermarket brands.
Old 07-06-2013, 07:25 PM   #6
Turbo99
Turbo99's Avatar
I am leaning towards MSD wires they are not really expensive and I know they have low resistance looking at all the data on other forums.
Old 07-06-2013, 07:52 PM   #7
Supercharged SS
Drives: 2010 Camaro
I'm on the stock wires and have always been. I think they finally put new ones on a few months ago. The originals went over 3.5 yrs.
Old 07-06-2013, 08:14 PM   #8
Turbo99
Turbo99's Avatar
Yeah I have a thread on my issue so not sure its the wires but its a easy cheap place to start after plugs. I logged some today and showed a misfire on #8 10 times in 1 second at 4900rpm and #7 6 times in 1 second. I have lost 4-5mph in a 1/4 mile run.
Old 07-06-2013, 08:16 PM   #9
Supercharged SS
Drives: 2010 Camaro
I had a similar issue. Mph was way down. Turns out I had a bad wire. If you're taking them off to inspect them you may as well replace them. Ted installed some heat socks. Look cool, work mint. No more 7 cylinder passes.
Old 07-06-2013, 08:20 PM   #10
Turbo99
Turbo99's Avatar
Yeah mine is weird only misses when hot at around 4500-5500 RPM then it clears. Like I say not sure what it is, gotta ask Ted what he thinks I should log, I am going to send him what I took today but the PIDs I did may not be what he wants.
Old 07-06-2013, 08:23 PM   #11
Supercharged SS
Drives: 2010 Camaro
Mine was in the upper rpm band as well. I think it was still cutting 1.4/1.5 60's but then going 10.2-10.3 at 131 mph. This was over a year ago so I'm not exact on those numbers.
Old 07-06-2013, 08:27 PM   #12
Turbo99
Turbo99's Avatar
Yeah I was hoping for 11.0-10.9 pass because the car hooked the best it ever has ...lol 1.75 60ft and I only trapped 122 and normally 126-127 and ran a 11.35. I could tell everytime I shifted the car would go flat for a second and then I could feel it pull...every shift was like that.
Old 07-06-2013, 08:30 PM   #13
Supercharged SS
Drives: 2010 Camaro
Def seems like a faulty wire. Start with that and go from there.
It wasn't until they had the wires off and on the bench that they found the minuscule slice in the wire. Couldn't see it on the car.
Old 07-06-2013, 08:36 PM   #14
Turbo99
Turbo99's Avatar
Yeah just switched to the ZR1 plugs about 3000 miles ago like Ted wanted so should be those but who knows.
