Old 07-06-2013, 06:18 PM   #1
pb23r
Drives: 2013 ZL1 (black)
Water marks on the wind shield...
Hi all - spent a good bit of time reading and learning how to wash my car (or at least not ruin it!). Many thanks to all who contribute.
I am having a *terrible* time dealing with water marks on exterior glass. The wind shield might look pretty good from a distance, but on a sunny day at the righ angle - its terrible! And distracting while driving.
Does any one have any tips? Water is quite hard around here making washing a challenge...
Thanks!
Last edited by pb23r; 07-06-2013 at 07:34 PM. Reason: Still learning to spell... :)
pb23r is offline   Reply With Quote
Old 07-06-2013, 06:24 PM   #2
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
awaiting an answer for this one too.
Old 07-06-2013, 07:09 PM   #3
Tecca
Tecca's Avatar
Drives: ...
I would start off and clay your windshield, if still present then go with a 1:1 mixture of water and vinegar. If you still have some spots go in with some 0000 steel wool.
Other options would be using ceriglass by hand or with a DA.
Tecca is offline   Reply With Quote
Old 07-06-2013, 07:23 PM   #4
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: 2015 Spice Red Metallic 2LTZ Impala
I don't know about the steel wool but I did use the vinegar and water with newspaper. Use the B&W type not the color.
Baldman is offline   Reply With Quote
Old 07-06-2013, 07:34 PM   #5
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
I can not help you with water spots I forgot how I got mine off. I have the same problem. I do this when I wash my car. Just as soon as I wash the roof and windows I will dry the windows. Then I try and keep as much water from hitting the glass. After I wash the hood I dry the windshield and side glass. I do this every time I get the windows wet. It takes alittle longer to wash the car but I do not get the water spots.
Caddy
Caddyroger is offline   Reply With Quote
Old 07-06-2013, 07:35 PM   #6
pb23r
Any recommended cleaning solution? I would be pretty nervous with vinegar & water on a brand new car!
Old 07-06-2013, 07:42 PM   #7
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
Here's what you need, Bar Keepers Friend. Put some a bowl, add a little water until becomes a soupy mixer. Using a mister or Windex spray bottle spray a light coat of water or Windex, apply the Bar Keepers Friend soupy mixer using a clean towel......small area's at a time. Clean with a dry towel, you should be able to find this at Wallmart....if not Amazon has it.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 07-06-2013, 07:48 PM   #8
Tecca
Tecca's Avatar
Drives: ...
I guess I could have suggested muriatic acid. Seriously vinegar will not do any damage. If you still don't feel comfortable here the use the 0000 steel wool.
Disclaimer: Don't use steel wool to remove water spots on your paint.
Old 07-06-2013, 07:51 PM   #9
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Tecca is right on with the 0000 steel wool. It nor vinegar won't hurt your cars windows.
But if you're still worried, just polish it. Meguiar's Ultimate Compound by hand should be able to remove waterspots pretty easily.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 07-06-2013, 10:26 PM   #10
pb23r
Many thanks for all the good advice!
Old 07-06-2013, 11:40 PM   #11
otter
otter's Avatar
Drives: Eastbound and Down
I have had really good luck with water and vinegar and it's very safe.
For spot prevention I use Rain-X on the windows year round. It seems to help.
otter is offline   Reply With Quote
Old 07-07-2013, 09:41 AM   #12
eb_SS
Drives: 2011 Camaro 2SSRS SGM
I use a clay bar.
Here are a couple tutorials courtesy of Adam's.
Longer videos:
Part 1
Part 2
-EB
eb_SS is offline   Reply With Quote
Old 07-08-2013, 01:19 PM   #13
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
I bought the Nanoskin Autoscrub Wash Mitt to prep the car for waxing but also realized that its great for removing water marks on the OEM stripes and glass.
Just a thought.
edgehead2000 is offline   Reply With Quote
Old 07-08-2013, 01:54 PM   #14
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Originally Posted by eb_SS View Post
I use a clay bar.
Clay bar is a great place to start, although it won't touch really stubborn water spots (neither will any of the clay alternatives).
I have nothing else to offer other than to echo the comments above.
My water spot removal steps go as follows (obviously stopping when something works):
Clay
Vinegar
Steel wool w/ glass cleaner for lube
As with anything, the best offense is a good defense. Wash in the shade if possible (nothing wrong with washing at night, either). Keep the car wet until you're ready to start drying the entire car. You guys know the drill.
[B]
