Old 07-06-2013, 09:17 PM   #1
jcieutat
Drives: 2013 SS 1LE
Post Lowering question for 1LE
I replaced the factory springs with a set of Eibach Pro Kit springs today. Once I finished up, I took it around the block to feel the ride and let the suspension settle. After parking it I noticed that the front wheels are sticking out past the fender. It may have been that way before and I just never noticed. It is not a negative or positive camber issue as it is pretty uniform. It kind of has me worried in the event that I hit a large bump and the wheel hits the upper fender. Anyone else notice this on their car? It will be getting a four wheel alignment on Tuesday at my local Chevy dealership.
2013 Camaro 1SS 1LE Inferno Orange
jcieutat is offline   Reply With Quote
Old 07-06-2013, 09:38 PM   #2
Jaydog760
Jaydog760's Avatar
Drives: 2013 Camaro SS/RS 1LE
Hmmm...mine is sitting on Pfadt 1.25" and just looked, flush with fender like the rear (305s on mine). Dunno
2013 Camaro 2SS/RS 1LE (black) ** 630rwhp - 590rwtq ** (Mustang Dyno) Maggie TVS2300, OD cog, 3.6 pulley, custom (mild) blower cam, ID850 injectors, ADM FPCM, Cold Air Inductions intake, Melling oil pump, ECS tensioner, Kooks headers, Magnaflow X pipe, Mild to Wild, NPP exhaust, Prosport gauges, Pfadt springs and trailing arms...all installed by Mike and tuned by Ryne @ Cunningham Motorsports
Jaydog760 is offline   Reply With Quote
Old 07-06-2013, 09:40 PM   #3
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
Im dropped on Pfadts 1 - 1 1/4" drop springs and no real issues with rubbing and have full turn radius.
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 07-06-2013, 10:48 PM   #4
jcieutat
Drives: 2013 SS 1LE
I think the turn radius is going to be fine, it just looks weird. The rear tires are flush. I just can't see how swapping out springs would push both of the wheels outward.
Old 07-07-2013, 12:05 AM   #5
1leNPP
Drives: 1LE , 1SS , NPP
If you have not done so already you mite post this in the Suspension , chassis part of the forum you mite get more help there .
1leNPP is offline   Reply With Quote
Old 07-07-2013, 07:37 AM   #6
jcieutat
Drives: 2013 SS 1LE
I went ahead and posted it over in the suspension section. I initially posted it over here since our cars have a wider front wheel than the standard SS.
Old 07-07-2013, 10:26 AM   #7
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
When you swapped springs the upper slotted Strut bolt hole probably didn't get lined up in the exact position it was before.
Once you get it aligned with the correct negative camber,it won't look to be sticking out from the fender anymore.
It has nothing to do with your spring swap.
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 07-07-2013, 11:16 AM   #8
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
This.
Even in the pictures it looks like the cambers are actually positive (when what you want them to be is slightly negative). Negative camber will pull the tops of the tires inward.
FWIW, if the strut fasteners had been put back exactly where they were originally, the lowered ride height would pull the cambers more negative, not less (and certainly not over into positive).
Norm
Norm Peterson is offline   Reply With Quote
Old 07-07-2013, 12:47 PM   #9
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
When you get the alignment,first time the bushings!
rockrau is offline   Reply With Quote
Old 07-08-2013, 10:01 AM   #10
PhoenixSS
Black 2011 2SS/RS
Drives: 2011 2SS/RS
How would you fix this, if that happened?
PhoenixSS is offline   Reply With Quote
Old 07-08-2013, 10:51 AM   #11
Norm Peterson
Adjust cambers using the adjustment method shown in one of the Pedders pages. It doesn't appear to be very difficult to do, and you could use a digital angle finder to measure your results if you're up to making a DIY attempt at this (seriously).
Keep in mind that as camber varies, toe usually does as well, and you really want to get that fixed. Bad toe is quite a lot harder on tires than a similar amount of camber error.
Norm
Old 07-08-2013, 12:57 PM   #12
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
If you have not had the alignment and bushings timed since your spring install,I would have it done ASAP.
Bruce@raymondsperformance is offline   Reply With Quote
Old 07-08-2013, 01:01 PM   #13
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 07-08-2013, 03:53 PM   #14
jcieutat
Drives: 2013 SS 1LE
I made the alignment appointment for Wednesday morning. It will be parked until then!
