Emblempros
Old 07-06-2013, 10:01 PM   #1
cbeech70
Drives: 2013 v6 6speed
V6 to V8 manual trans swap.
I want to put a v8 manual trans in my V6 2013, Can this be done? I am turbo charging my car and don't think the v6 trans will hold up. Can it bolt up? I'm working on getting the axles ect.... from a SS.
cbeech70 is offline   Reply With Quote
Old 07-06-2013, 10:40 PM   #2
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
I don't know the answer to your question, but I will be selling my m6 soon. PM me if interested, trans works perfect and the clutch is perfect too. Going with a dedicated drag setup with a th400!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 07-06-2013, 10:48 PM   #3
cbeech70
Thanks.
Old 07-06-2013, 10:58 PM   #4
Basemaro
Drives: 2015 BLACK LFX M/T
Why not just change the clutch out and maybe the driveshaft a long with the axles. They don't have to be from an SS.
Basemaro is offline   Reply With Quote
Old 07-07-2013, 03:37 AM   #5
Synner
Drives: not stock
No it won't bolt up and will take a fair amount of custom work until/if/when someone makes a kit.
Synner is online now   Reply With Quote
Old 07-07-2013, 02:26 PM   #6
cbeech70
Does anyone know how well the v6 trans will hold up? From what I'm seeing I am looking in the 450 ft/lb and 475 to 500hp at the crank. I had a 91RS with the old T5 and went through 5 before I gave up. Hopefully this is a much better trans.
Old 07-19-2013, 11:13 PM   #7
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
The numbers I see on the web are 345 ft-lbf of torque. Doesn't look promising.
Mark114 is offline   Reply With Quote
Old 07-20-2013, 07:43 PM   #8
2014v6
2014v6's Avatar
Drives: 2014 black 2 LT
have you thought about also putting a solid rear axle in the rear with the copo rear plate kit?
Ordered:May 18 2013
2000 status 6-11-13
3000 status 6-12-13
TPW 7-22-13(6-14-13)
3300 status 6-28-13
3400 status 7-18-13
3800 status 7-20-13
4200 status On its way home
6000 status 7-31-13 first camaro ever...
Sold 7-5-14.. thank you oshawa assembly
2014v6 is offline   Reply With Quote
