BeckyD @ James Martin Chevy
Old 07-07-2013, 02:21 AM   #1
2ssx2
2ssx2's Avatar
Drives: 2013 2ss se/ 2009 cobalt ss
Concerned about performance.
I could not perform for my wife today. Haha
I went out too the drag strip today for my birthday and made 2 passes on my car for the first time.
My numbers are as posted:
R/t .256
60ft 2.103
1/8 8.58
1/4 12.9 @111.5
I realize I can get my 60ft times way down and that is driver/ tire issues but even then I do not believe this car is performing the way it should.
I have a 2013 ls3 with an edelbrock supercharger,NPP exhaust and Jennety tuned.
Need some advice on the car performance.
2013 Special edition 2SS/RS, dual mode, sun roof, Nav, edelbrock SC, JRE tuned, tinted windows.
2ssx2 is offline   Reply With Quote
Old 07-07-2013, 09:58 AM   #2
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Stick?
Try different shift points.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-07-2013, 11:48 AM   #3
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
Originally Posted by Pro Stock John View Post
Stick?
Yea he said LS3. What are you shifting at rpm wise? What are you launching at? With those mods you should be way quicker.
45thAnniversary2SS is offline   Reply With Quote
Old 07-07-2013, 11:55 AM   #4
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
What does that have to do with your car?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 07-07-2013, 12:35 PM   #5
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
Should definitely be faster than what you're showing. Times could also be effected by weather? What were the weather conditions, track elevation? Track location?
Jason@ is offline   Reply With Quote
Old 07-07-2013, 01:13 PM   #6
2ssx2
2ssx2's Avatar
The track elevation is 400ft. And the air temperature was around 75.
I am launching around 2800 rpm. I used to drag my cobalt SS quite often so I am familiar with the track. My cobalt would trap speeds of 115 plus and spinning down the track.
Old 07-07-2013, 01:21 PM   #7
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
what kinda boost u running ?
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 07-07-2013, 01:42 PM   #8
2ssx2
2ssx2's Avatar
I do not have a boost gauge but based on the data log conversion I am running about 6.8.
Old 07-07-2013, 01:44 PM   #9
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
That's strange I would at least expect your trap speed to be higher. You are running what a stock 1LE would run.
CamaroTom is offline   Reply With Quote
Old 07-07-2013, 01:56 PM   #10
2ssx2
2ssx2's Avatar
That is exactly what I am thinking. It is like the supercharger is not there. The trap speed should be way way higher. Even spinning in first and second. I have done several data logs in the past and finally gave up. I noticed KR quite a bit with a 92 octane tune and our gas here is 93. I did some testing by throwing octane boost in the car and data logging again. The KR went down significantly proving to me the assholes around here are not putting 93 octane In there tanks.
Some days the car feels pretty fast and some days not so much. I feel like I wasted my money on the supercharger and maybe the car. I am a little frustrated
Old 07-07-2013, 01:56 PM   #11
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
R/t .256
60ft 2.103
1/8 8.58
1/4 12.9 @111.5
60ft is hurting your ET quite a bit but your mods should be pulling more mph than 111.5?? Have you data logged your runs? Tune could be off? What was the DA on that run?
Camarojt is offline   Reply With Quote
Old 07-07-2013, 02:21 PM   #12
Fore58
Drives: 2011 L99 Camaro
What was your rwhp results?
Fore58 is offline   Reply With Quote
Old 07-07-2013, 02:28 PM   #13
2ssx2
2ssx2's Avatar
I did not data log the runs but will do that on Friday.
Old 07-07-2013, 02:31 PM   #14
2ssx2
2ssx2's Avatar
Car has never been on a dyno but conservatively speaking shoul be around 490 rwhp i would think
