HURST
Old 07-07-2013, 10:10 AM   #1
the_fast_one
the_fast_one's Avatar
Drives: 2012 IOM 2SS, 05 SOM Colorado
Am I forgetting anything.
My car is going in for a cam and some other things. I am trying to set it up so when I add an ECS supercharger I wont have to add much more than what the kit comes with. Anyway here is what I have and whats going on the car in a bit
Halltech CAI,
Apex race scoop
LPE GT9 cam
PRC 6.75 springs
Speed Inch Chromemoly 7.400 push rods
Comp Cams Rocker Arm Trunion Upgrade
SLP double roller timing chain
SLP 160* Thermostat
SLP 25% UD Pulley
Melling High Volume Oil Pump
MSD wires
NGK TR6 plugs
2" Kooks Headers with out cats
NPP exhaust
Various ARP bolts
So am I forgetting anything before it goes to the builder or is this a good start? It is my first time building a car and want to do it right
Let the modding begin
466/436 - JRE Rough Idle blower cam, BTR push rods, PRC 6.75 springs, halltech CAI, K&N filter, SLP 25% UD pulley, Manley H/V oil pump, Kooks 1 7/8 headers w/o cats, ported TB, Npp exhaust. BMR 1.4"/1" drop springs, ZL1 Swaybars, 1LE strut tower brace, zl1 rockers, zl1 style splitter, night shades ns3 stripe kit.
Future mods
Dss 1000hp axels Dss aluminum driveshaft, bmr full bushings, ? Clutch, ? Supercharger, wheels/drag radials.
the_fast_one is offline   Reply With Quote
Old 07-07-2013, 10:13 AM   #2
Gunslinger09
Drives: 2010 Camaro SS
The tune and dyno time.
2010 Camaro SS
Black/IOM
Gunslinger09 is offline   Reply With Quote
Old 07-07-2013, 10:16 AM   #3
the_fast_one
The install and tuning and dyno time is going to be handled by Speedinc in Schaumburg IL
Future mods
Old 07-07-2013, 10:30 AM   #4
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Auto or manual ? Looks like a great start, most would be done after all that. Lol. Watch your wheel hop, more critical on manuals. Enjoy
Mchlgrrsn is offline   Reply With Quote
Old 07-07-2013, 10:44 AM   #5
the_fast_one
Manual.
This winter I am going to build the suspension and probably do Axles and DSS aluminum driveshaft and possibly do a Katech LS9R clutch kit
Future mods
Old 07-07-2013, 10:50 AM   #6
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Originally Posted by the_fast_one View Post
Manual.
Rear trailing arms and subframe connectors should kill well hop. You can do more but I think it's overkill. Wheel hop can and will break parts, trust me.
Old 07-07-2013, 10:51 AM   #7
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Manual.
That will be necessary once you go FI
Old 07-07-2013, 11:11 AM   #8
the_fast_one
Yeah I do not plan on doing anything major with suspension just what you mentioned along with stock strut tower brace, lowering springs, and either 1le or zl1 sway bars.
Future mods
Old 07-07-2013, 02:24 PM   #9
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Go with a c5r timing chain instead of the double roller
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 07-07-2013, 02:30 PM   #10
Synner
Drives: not stock
Yeah the double roller requires clearancing the back of the timing cover. And the double is just extra weight compared to the c5r. Since you're sending it somewhere they have the fluids and incidentals covered. I would assume they have any gaskets you'd need on hand due to volume.
Old 07-07-2013, 02:31 PM   #11
Synner
Drives: not stock
Oh and I wouldn't do an underdrive pulley if you plan on going FI. Go with a stock diameter to control vibes.
Old 07-07-2013, 03:27 PM   #12
the_fast_one
I was planning on doing the C5r chain and stuff but It was cheaper to do the SLP double roller with 3 bolt design. I know they are really unnecessary but the deal was good. They will do all the clearancing during the install. I would not think the weight difference would be much.
Shop specializes in LS builds so they have all gaskets, fluids, and incidentals covered and included in the build cost.
It will be coming off when the SC goes on next year and replaced with stock size one. But I want to squeeze some more hp out in case something happens money wise and I have to put off the supercharger.
Thanks for the replies guys
Future mods
