Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 07-07-2013, 10:25 AM   #1
1st Car :D
Drives: V6 1lt Black with two silver stripe
Best 2012 v6 Drop Springs?6
Ive been looking to lower my ride and i wanted to add drop springs ecause they arent to expensive, and will add a nice look. I just dont know which ones to go with if some of you could show me some pictures of how they made your car look and how it feels that would be greatly appreciated. Also what is the ease of installation?
AMPCamaro is offline   Reply With Quote
Old 07-07-2013, 11:33 AM   #2
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
PFADT 1.25" I love them and ride is no different unless you hit BIG bumps then it hits hard but your supposed to swerve them potholes!
JantzenOKC is offline   Reply With Quote
Old 07-07-2013, 11:48 AM   #3
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Installation is not too difficult, as long as you're not freaked out by springs under tension. Use a good spring compressor and be careful. Air tools help a lot.
Make sure to have arrangements for an alignment after you are done.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 07-07-2013, 12:43 PM   #4
KMPrenger's Avatar
Just did springs on my 2010 a few weekends ago. A 2nd set of hands can be really helpful so I'd have someone available to help if you need it, but honestly the install was not bad. Wish I had done it a long time ago.
I don't know about the 2012+ models, but on my 2010 we didn't even need a spring compressor. Removing the final nut from the top of the struts only resulted in a little pop off from the was barely compressed.
We also used air tools...big help.
Old 07-07-2013, 12:54 PM   #5
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
Eibach Pros..don't really need a spring compressor..under $20 @ Harbor Freight if you must have one. dropped 1-1.5 "..looks great, good ride(obviously not as soft as stock).
Old 07-08-2013, 12:12 AM   #6
delta6's Avatar
Drives: 2012 Camaro TF3 #427
“The winner ain’t the one with the fastest car, it’s the one who refuses to lose.”
delta6 is offline   Reply With Quote
lfx, lowering springs, v6 engine
