Rick@Livernois
Old 07-07-2013, 10:50 AM   #1
Camonster
Drives: 2013 Rally Yellow Camaro 2SS/RS
Vortech Supercharger
I'm considering buying the Vortech kit for my '13 SS. The complete kit is only for the '10 and '11, the kit available for this years model is a tuner kit, without any fuel management upgrades. I have never majorly upgraded a car before, and certainly never dealt with any forced induction. With this "tuner kit" will I need professional installation and tuning? Also, will I need to upgrade anything else to protect the car? Everything is stock with the exception of my K&N air filter.
Camonster is offline   Reply With Quote
Old 07-07-2013, 11:03 AM   #2
thebeast916
Drives: Blown G8 GT
Nothing "has" to be done.
Bolting it up on a completely stock car will warrant decent gains.
Just consider at least injectors, bap, and a proper tune.
It is recommended that you install headers and an exhaust for optimal gains for a boosted application.
From there, heads, cam, meth, fuel system, more boost, etc. options are endless.
And if you don't have alot of knowledge working on cars, it would be wise having a shop install and tune it.
thebeast916 is offline   Reply With Quote
Old 07-07-2013, 11:17 AM   #3
2012REDSS
Drives: 2012 Camaro SS
the tuner kit requires that you source the fuel componets yourself such as injectors and you will need to have it tuned due to the tuner kit does not come with the sct handheld with the base vortech tune. The 10-11 complete kits will fit however Vortech does not have an updated tune for the 12-13s. Ask me how I know. If I was you I'd get the tuner kit, 65psi injectors or larger, ZL1 fuel pump with ADM FPCM or if you don't plan on cranking the boost get a MSD BAP. Look hard at the V3 kit compared to the ECS kit. If I had to do it over I would go ECS. Way better number down lower in the rpm range and their customer support is awesome. I'm not too disappointed with the V3 but I'll be stepping up to the YSI in the near future since it will bolt into the same brackets. My V3 made 565rwhp and 498rwtq on 9-10psi and 607rwhp and 525rwtq on 12 psi. Both pulls stopped at 6200rpm and I was running 22's.
2012REDSS is offline   Reply With Quote
Old 07-07-2013, 11:44 AM   #4
Camonster
Is the factory Dual Mode exhaust system not enough to handle the added power? It's almost a $2000 option, you would think...
Old 07-07-2013, 11:57 AM   #5
2012REDSS
It will handle the base kit just fine but your numbers will be lower. Long tube headers/no cats really wake these cars up. I had ported TB and Intake manifold, Lts, no cats and 3in exhaust before I went with the V3.
Old 07-07-2013, 12:17 PM   #6
Unreal
Drives: 2006 Z06
Look into turbos. Turns out to be cheaper, more power, and drives better.
Nick
Corvette Z06 -1200ish rwhp
Old 07-07-2013, 11:50 PM   #7
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Talk to any of the ECS dealers. Their base kit uses the NOVI 1500SL which is equivalent to a Vortech V2 T-Trim, (825+ hp) but self-lubricated. Vortech manufacture both Vortech and Paxton, so there really isn't much to decide with, but the ECS base kit will support more power than V3, no offense 2012REDSS. It is also upgradeable to the Ysi, which is something I'm also looking into myself. You'll a lot of people arguing turbo vs. S/C and which brand to use. No matter what you choose, you'll be happy either way. Going FI is always a fun decision once completed.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 07-08-2013, 01:14 AM   #8
2012REDSS
No offense taken...I even said if I had to do it again I would go ECS
Old 07-08-2013, 09:24 AM   #9
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
V3 has nothing to do with the size of the blower. The trim does. I have an Si trim on a stock cammed L99 with headers and fueling mods and am very happy with it. I'm getting 12 psi, still running the restrictor (ground down some) and not over spinning the blower. There is alot more to be had. I'm betting I could put in a moderate cam, remove the restrictor, over spin it a bit and still make 12+ psi. Not saying the Novi 1500 or a T trim isn't the way to go, I'm saying the Si trim in an ECS kit should not be overlooked. It's alot more than an S trim (actually closer to a T trim) and is super efficient. And it also can be swapped outfit a YSI should you ever want to go north of 800.
Matt of FSP actually sold me a used V3 Si trim along with a new ECS kit. Saved me a chunk of change!
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 07-08-2013, 12:44 PM   #10
2012REDSS
Mine is a Si trim same as yours...ECS's numbers are still better then mine in the low end and I have a stick...although my 3.91s make up for it
Old 07-08-2013, 01:51 PM   #11
Chris82xx
Chris82xx's Avatar
What makes the difference between the Si and T trim is the impeller, the inlet diameter, and just some light variations between the volute.
811RWHP/719RWTQ
Old 07-08-2013, 02:30 PM   #12
grocerygetter
instigator
grocerygetter's Avatar
vortech or ECS...either is good for sure. For fuel I recommend the same as said above, you'll need a local shop to tune/install if you are doing a tuner kit from vortech. 65lb+ injectors plus ADMfpcm and ZL1 fuel pump.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 07-08-2013, 03:24 PM   #13
Ivan @ Southwest Speed
Get with Matt at FSP. There is no better person here on Camaro5 that can and will help you with Centrifugal blowers than him. Hes a good fella and has unbeatable service and prices.
http://www.camaro5.com/forums/member.php?u=71056
Good luck in your quest for power friend!
Old 07-08-2013, 03:37 PM   #14
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
I can make the kit specifically for your car with Custom tuning to go along with it.
We did the first 2013 install of a Vortech kit Here in my shop when we built the Convertible for The SEMA show.
Just give me a call.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
forced induction, supercharger, vortech
