sjm autoprod
Old 07-07-2013, 12:05 PM   #1
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Disappointed in results from FTI convertor
I installed a 3400 FTI convertor into my 2012 LFX. When I go to launch the car it slowly goes up in RPM than about 1/2 second later flashes to about 1700/1800 RPMs. I am leaving from footbraking, not preloading the convertor. I've had stall convertors before and never felt anything like this. Now this is my first computer controlled car I'm modding. Now if I let off the brake pedal for a second at idle than hit it, it will flash about 2600. Maybe some tuning needs to be done to correct this?? I am using HP Tuners software and have just started remote tuning with Matt@FSP. This was happening before using the HP Tuners software.
etmx183 is offline   Reply With Quote
Old 07-07-2013, 12:07 PM   #2
Supercharged SS
Drives: 2010 Camaro
Did you get it from RX?
Old 07-07-2013, 12:32 PM   #3
CFD
Drives: 2SS/RS L99 BLACK
I have a FTI 3600 stall and am also unhappy with it. It launches well but is all over the place with normal driving.
CFD is offline   Reply With Quote
Old 07-07-2013, 03:55 PM   #4
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
Sorry to hear that, that's too bad... After my first trip to the track with my 13 2LS, I was thinking the best mod I could do for the car for better ET's would be a higher stall converter, and I was considering the FTI... Perhaps I will look elsewhere. Keep us posted.
Jason@ is offline   Reply With Quote
Old 07-07-2013, 05:19 PM   #5
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
That's not your convertors fault. Not sure how the 6l80's tuning works if it works off slip or pressure or what.. But I would think normal driving non Wot it would lock up rather nice if your trans tune is ok.
JLE58 is offline   Reply With Quote
Old 07-07-2013, 05:23 PM   #6
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
Matt will fix you up.
Old 07-07-2013, 05:23 PM   #7
JLE58
Matt will get you worked out bud. Let him gather some data and I'm sure he will figure it out.
Old 07-07-2013, 05:32 PM   #8
CFD
I thought it was in the tune as well but where as I do not do my own tuning and after several sessions of data logging and attempts to correct it the tuner is confident it's a loose converter, could he be wrong, very possible but he is very qualified so that's what I am going on.
Old 07-08-2013, 06:58 AM   #9
etmx183
etmx183's Avatar
Thanks for the feedback. I'll be doing some data logging this week for Matt and will post results.
Old 07-08-2013, 03:02 PM   #10
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
The TCC does partially apply on the factory converter. It should be tuned to allow 0 slippage with an aftermarket converter. Single or triple disk.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 07-08-2013, 06:31 PM   #11
CFD
I am not seeing TCC desired slip set at zero except for 1st gear, perhaps this is the reason?
Old 07-08-2013, 09:25 PM   #12
etmx183
etmx183's Avatar
Thanks for the feedback, on the highway it is great. Lock up in 4th/5th and 6th. It is the launch that is not stalling when I footbrake. i have to be off the brake for a second than whack the throttle for it to stall. If I hit the throttle at the same time I release the brake pedal it acts like it is cutting power for a second than takes off. Never had this issue with the stock convertor.
Old 07-08-2013, 09:59 PM   #13
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Just need some datalogs and we'll see whats going on.
Only thing I did over the holiday weekend was write a base tune for him so he can start doing some logging, etmx said I'll get some logs during the week but its very hot up there so probably later in the week.
Matt @ FSP is offline   Reply With Quote
Old 07-08-2013, 11:40 PM   #14
butters
It's not the batmobile!
butters's Avatar
butters is offline   Reply With Quote
