Old 07-08-2013, 08:46 AM   #1
HaulnSS
2013 2SS/RS M6
HaulnSS's Avatar
Drives: 2013 2SS/RS M6 Dual Mode
2013 2SS/RS Measurements for custom wheels
Does anyone have measurements for the attached PDF file? If you have them with a 1" drop, would be even better.
Thanks!FeslerWheels_OrderForm2.pdf
Hurst, Mojave Interior, 20% tint, Dual Mode Exhaust, ZL1 Splitter, ZL1 rockers, Blade spoiler, 3D Carbon rear quarter spats, CAI, Headers, M2W, catch can, apex scoop, LED DRL's, smoke side markers, billet aluminum SS emblems, Street Scene lower grill with scoops, BMR subframe connectors, lowering springs, bushings. Forgeline 20" w Nitto 315/275
HaulnSS is offline   Reply With Quote
Old 07-08-2013, 08:57 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Here you go, figured I'd teach you how to fish vs giving you a fish.
Originally Posted by Sir Nuke
Wheel Offset
Offset is measured from the centerline of the barrel of the wheel to the hub mounting surface. If that hub mounting surface were in the exact center of the barrel of the wheel the offset would be “0". If the mounting surface is away from the center of the wheel the offset is POSITIVE, if the mounting surface is towards the center, the offset is NEGITIVE. Offset is measured in millimeters. There are 25.4 millimeters to an inch. So if the mounting surface is 12mm from the centerline of the wheel it has a 12mm offset. That would also mean that it is about ½ inch. If the mounting surface is moved away from the vehicle that is a positive offset. The picture shows a wheel with the positive offset. A positive offset will cause the wheel to set in or tuck into the vehicle. Originally you found positive offsets on just front wheel vehicles. Due to that some people refer to positive offset wheels as front wheel drive offsets. Currently there are many rear wheel drive cars and trucks with positive offsets. The higher the positive offset the less it sticks out from the vehicle and it will have a higher Backspace. If the mounting surface is moved in toward the vehicle past the centerline, that is a negative offset. A high negative offset will produce a lower Backspace. Once again the measurement in millimeters is how far away from the centerline the mounting surface is. A -24mm offset means that the mounting surface is located 24mm or 1 inch from the centerline toward the vehicle. The wheel will come out farther from the vehicle and will have that deep dish look.
Width
The width of a wheel is measured inside the beads which are usually ½ inches. If you measure on the outside of the beads an 8 inch wheel will measure 9 inches
Backspace
Back spacing is measured from the inner edge of the wheel to the hub mounting surface. It is a convenient measurement in that, as long as the back spacing remains the same, the clearance to the suspension also remains the same. If you know the width of the wheel and the offset you can compute the backspacing. For example if you have an 8 inch wheel with a +24mm offset. An 8 inch wheel is actually 9 inches wide so if the offset were 0 the mounting surface would be right on the centerline and the backspacing would be 4.5 inches. With a positive offset the mounting surface moves off center 24mm or 1 inch toward the outer edge of the wheel. This will make the inner edge go more inside which will result in a 5.5 inch backspacing.
Centerbore
This is the diameter of the center of the wheel. The centerbore must be equal to or larger than the hub of the vehicle for the wheel to seat. If the wheels centerbore is the same as the hub on the wheel then that wheel is hub-centric and uses the hub to center the wheels. If the centerbore is larger than the hub then the lugs will center the wheel and that is lug-centric. When using a lug-centric wheel be sure and snug the lugs up slowly and tighten them in an opposite or star pattern.
Bolt pattern
A bolt pattern of 5x120 mm means it has 5 lugs and if there were a circle through the center of all the lugs the diameter of that circle would be 120 mm.
and here's the thread about it: http://www.camaro5.com/forums/showthread.php?t=111604
Click to view my build thread
Old 07-08-2013, 09:05 AM   #3
HaulnSS
2013 2SS/RS M6
HaulnSS's Avatar
Thank you Stig, does that give me back spacing only? The company won't place the order for the wheels unless I have all the measurements on the pdf file.
Old 07-08-2013, 09:15 AM   #4
The Stig
The Stig's Avatar
If you look at the PDF it has each measurement labeled A, B, C, and D. They line up with the measurements on the photos I attached.
Old 07-08-2013, 09:18 AM   #5
HaulnSS
2013 2SS/RS M6
HaulnSS's Avatar
I will give it a whirl, Thank you!
