Old 07-08-2013, 08:28 AM   #1
Chevy9534
Chevy9534's Avatar
Drives: 2013 2ss/rs
Lg lowering springs
Since i installed my lowering springs i have a squak type noise from the rear over certain bumps. I took them off and lubed all rubber to metal contacts and it still has the noise. Any suggestions?
Chevy9534 is offline   Reply With Quote
Old 07-08-2013, 10:33 AM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Do they have any plastic sleeves over some of the coils? Maybe call or go by LG and have them listen and give you any suggestions.
Build Journal
Old 07-08-2013, 10:44 AM   #3
Chevy9534
Chevy9534's Avatar
Drives: 2013 2ss/rs
No sleeves over any of the coils
Old 07-08-2013, 11:49 AM   #4
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
That is most likely your problem. It happened to me when one fell off and I noticed a noise where there had not been a noise there before.
ZL1-V is offline   Reply With Quote
Old 07-08-2013, 11:59 AM   #5
caverman
caverman's Avatar
Yes....pretty much all the springs have sleeves on a coil or two to keep them from making noise. Check with LG and see if there were supposed to have sleeves and see it they'll let you switch them out with some that have them.
Build Journal
Old 07-10-2013, 11:31 AM   #6
Chevy9534
Chevy9534's Avatar
Drives: 2013 2ss/rs
So i took the car and LG looked at it yesterday and they said the install is right, didnt ask about sleeves but i dont see them in any of the kits LG sells. Any idea what size sleeve you would get to install on them?
