![]() Drives: 2013 Camaro SS Join Date: Apr 2013
Magnaflow
Does anybody have any sound clips of a auto Camaro with a magnaflow 16581 axle back before and after removing the resonator and installing an x-pipe? I'm not happy with this axle back its not much louder than stock!! Just don't want to waste any money on the x-pipe if it's not going to make it sound better or make it lose power!!! Thanks for the input!!!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
On the A6 the huge resonator is your issue. Getting an x-pipe in place of that should help out the sound a bunch. However, you'll then hear the AFM big time which might annoy the heck out of you.
Build Journal ![]() |
![]() ![]() Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
I have solo hiflow cats and axelback but with the stock resonator it was loud but raspy just installed the magnaflow resonated x and it quieted down but the sound is great i do get afm since i removed the trash cans but i learned to get rid of it by changing pedal position slightly when it comes on
Ported intake manifold and throttle body kooks 2" headers no cats
The AFM is not an issue I just want to pickup more sound without being overkill!! I have also read in some posts that deleting the resonator and installing the x-pipe some have lost some bottom end power and I don't want to do that to the car!!! With that said do I x-pipe it or scrap what I have and go with a full cat-back?
![]() Drives: Chevys at the limit Join Date: Nov 2010
I suggest going with the Magnaflow Tru-X pipe and replacing the resonator with strait pipe. This will definitely give you a little more sound and will not hinder performance in any way.
You should also keep in mind, that even with no mufflers, Camaro's are somewhat quiet when you are still on the stock manifolds and cats. Once you do headers and high flow cat's, you will get a pretty big change in sound. Best regards, Tyler 888-308-6007
Thread Tools | |
