Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 07-08-2013, 08:49 PM   #1
LBreezie
LBreezie's Avatar
Drives: 2012 Camaro 45th anniversary
Suggestion on floor pans?
I need a quote on welding replacement floor pans in my 1rst gen? I need both back floor pans replace. Everything else is in good condition. here is the pics
LBreezie is offline   Reply With Quote
Old 07-08-2013, 10:36 PM   #2
shank0668
shank0668's Avatar
Drives: '00 WS6/'06 LJ/'76 Trans Am
Send a message via AIM to shank0668
Could always buy a welder and learn!
That's the route I took.
Old 07-09-2013, 01:45 AM   #3
LBreezie
LBreezie's Avatar
I have one, but a friend talked me out of doing the floor pans myself.
Old 07-09-2013, 09:51 AM   #4
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Speaking as someone who has done this before - I would suggest you cut out the cancer only and replace as little original metal as possible. The car will be stronger and more structurally sound that way. You can grind and smooth out the beads if you desire but it isn't an issue depending on the situation. Some cars need to look amazing when you see the bottom but not all. Use a MIG with gold gas and tiny wire and you will get the best results. I tried a Craftsman welder but sent it back and bought a Miller and never looked back. It is worth the extra bucks.
Hope this helps,
-Mark.
Old 07-10-2013, 12:47 AM   #5
flyingskibiker
flyingskibiker's Avatar
Drives: Cars, Trucks, Bikes, ORVs, Planes
Send a message via Yahoo to flyingskibiker
I'm right there with you! I need to replace the passenger rear... I bought a MIG welder awhile ago. I'm am "practicing" on my shifter hole. It is a LOT easier to cut out (repair panel) and get to when welding. It started out ugly, even practicing on scrap. But I think I got it down, now. The rear floorboard will be a challenge cutting for a proper fit. I think I have a good plan, though. Then again, I have been making a TON of excuses about getting to work on them... lol
1968 SS w/ 1966 427/425 Sequoia Green w/ Bumble Bee stripe. Always working on it...
Drooling over the ZL1s. It will be my next car if I can manage to pull it off...
flyingskibiker is offline   Reply With Quote
