Elite Engineering
Old 07-08-2013, 09:38 PM   #1
feo_gang
Drives: black 93 camaro z28 coupe
Need Help !!
I Have A 93 Camaro z28 , I Replaced The Ignition Coil And Module , my car cranks and drives but when it gets hot it cuts off and doesn't crank back up until the car cools down , can anyone help me with this ? Please
feo_gang is offline   Reply With Quote
Old 07-09-2013, 10:16 AM   #2
Chrisrp454
Chrisrp454's Avatar
Drives: 2010 ABM 2SS/RS M6, 98Z28 M6
When you say "doesn't crank'.
Does the starter turn over and act like it has no spark, or nothing happens when you turn the key?
Always Remember! Rest in Peace Brothers
9/11/2001. And thanks to all those who defend and serve!
Ordered 5/23/2009
3400 with TPW of 08/03/09
3800 8/11/2009
Arrived 8/21/2009 2SS/RS/Aqua Blue/Grey Interior
Chrisrp454 is offline   Reply With Quote
Old 07-09-2013, 07:12 PM   #3
feo_gang
the starter turns over and acts like it has no spark
Old 07-10-2013, 05:03 PM   #4
Yendor
Yendor's Avatar
Drives: 2012 Camaro 2SS/RS
you gotta prove that it is missing either spark or fuel first. You ever have optispark issues in the past?
I personally would pull a spark plug wire, take a old spark plug and push it into the wire and rest that against the engine to see if you are getting a spark. That's what I had to do the 95 Bird I had.
2012 RY 2SS/RS Manual/Factory Installed Hurst short throw shifter, Forgestar CF10 Wheels, Doug Thorley Cat back, CAI intake and Stainless Power 1 7/8" headers, Seibon Carbon Fiber "V" Weave hood and Carbon Fiber Trunk Lid.
Yendor is offline   Reply With Quote
Old 07-11-2013, 09:35 PM   #5
feo_gang
im quite sure it's the optispark , the car has never had a new one and it has 123k miles and it's showing all the signs of needing a new one
Old 07-11-2013, 09:36 PM   #6
feo_gang
the car is getting fuel we already proved that
Old 07-15-2013, 02:05 PM   #7
Chrisrp454
Chrisrp454's Avatar
How old are your plug cables? and are there any that might be melted thru. Such as laying on a header?
Ordered 5/23/2009
3800 8/11/2009
Old 07-16-2013, 10:53 AM   #8
Yendor
Yendor's Avatar
If it is the optispark you are not going to recover from it easily. 123k on a non-vented optispark is a lot. An optispark set up has a lot of parts. More than likely the cap and rotor have never been replaced. Even that requires the removal of the water pump. Good luck, its a pain in the behind.
Old 07-16-2013, 09:21 PM   #9
feo_gang
yeahh i figured good thing i have a good mechanic
Old 07-17-2013, 09:21 PM   #10
feo_gang
chris the person i brought the car from said the plug cables need to be rewired
