BORLA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 07-09-2013, 04:10 AM   #1
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
Using jack stands in a slope?
I am hoping to finally get my apex race scoop and heritage grille installed this week, and so I need to jack up my camaro in my driveway which has a slight slope. If I use jack stands and put 2 bricks or something behind the back tires will that be ok to keep the car from rolling down hill and keep it in place? I've jacked my car up on the driveway before, but i only took off one tire at a time, not 2 at once. Any insight is appreciated!
Aubrey64 is offline   Reply With Quote
Old 07-09-2013, 04:59 AM   #2
motorhead
motorhead's Avatar
I wouldn't do it on a slope, but I always error on the side of safety.
Old 07-09-2013, 06:36 AM   #3
Neumatic
Neumatic's Avatar
Drives: 2010 Camaro 2SS M6
Iv used some on a slope, however they were larger then most and had a pretty good size base.
Tuned by Back Street Performance 471hp/429tq
11.86 @ 117.47, 1.749 60'
Neumatic is offline   Reply With Quote
Old 07-09-2013, 07:14 AM   #4
Eich
Drives: '11 SW/Beige 2SS RS Manual
Really depends on how steep the slope is. Personally I'd avoid it and if you don't need to remove the wheels, I'd use ramps instead.
Eich is offline   Reply With Quote
Old 07-09-2013, 07:37 AM   #5
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
AND if you do the job in your drive way....not only would it be a good idea to block your rear wheels, ALSO you need to SET YOUR EMERGENCY BRAKE.
Old 07-09-2013, 07:46 AM   #6
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Personally I never recommended jacking on a sloped surface. With that being said if the slope is very minor you can just pull up the emergency brake and place a 4X4 behind your wheels for safety. A car jacked up on a sloped surface can easily fall off of normal jack stands which can potentially hurt you or damage the car/frame.
Proud owner of litho #179 Click Picture for Build Thread
Old 07-09-2013, 10:15 AM   #7
intensifi
Drives: '12 2LT Convertible
When I block my wheels I use 2"x4"s because I figure bricks are just tall enough to get pushed by the tires. Of course this has to be on a level or near level surface.
You can also use your emergency brake. However I think this only helps if the rear end is on the down slope.
Are you going to use a floor jack and jack stands?
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 07-09-2013, 11:09 AM   #8
cflbuckeye
Drives: 2012 Convertible Camaro 2SS w/RS
If all you're doing is removing the front facia, then you don't have to jack up the front of the car (assuming you're not lowered or having larger then 20" wheels). I just installed my ZL1 grill a few weeks ago and was able to do it by turning the front wheels to get to the bolts on each side. It really wasn't too bad at all.
cflbuckeye is offline   Reply With Quote
Old 07-09-2013, 11:24 AM   #9
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Originally Posted by menendez1293 View Post
A car jacked up on a sloped surface can easily fall off of normal jack stands which can potentially hurt you or [Strike]damage the car/frame.[/Strike] pop your head like a pumpkin.
Fixed.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 07-09-2013, 03:27 PM   #10
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
Agreed. You don't need to jack the whole front end up.
When I installed my intake and scoop/washer fluid bottle I only removed the front left wheel.
This was my procedure:
1. Turn wheels all the way to the left.
2. Engage parking brake.
3. Block rear wheels.
4. Break lug nuts loose on front left wheel.
5. Jack up front left of car and put on jack stand.
6. Remove lug nuts and front left wheel.
7. Remove front left wheel well liner.
8. Remove front right wheel well liner.
(Having the wheels turned to the left allows you to get the screwdriver
in there to remove the 5 screws of the right wheel well liner.)
9. Remove front fascia.
You already saw my how-to PDF so just follow that once you've got it up on the jack stand.
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller
Aesthetic Mods
Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items
snymat68 is offline   Reply With Quote
Old 07-09-2013, 03:58 PM   #11
Aubrey64
Aubrey64's Avatar
Awesome! Thanks for the help! Hopefully I'll finally get this done this week
Old 12-12-2013, 09:12 AM   #12
moondog933
Drives: 2010 Camaro SS
how bout leave it in park and set the parking brake ?? you won`t have any issues.
moondog933 is offline   Reply With Quote
Old 12-13-2013, 05:29 AM   #13
h018871
Geoff
h018871's Avatar
Drives: 2013 1LE Blue
One more comment:
Stick the wheel you removed under the car, right behind the now empty wheel well. This will save your legs should something shift.
Standard mods: cam, headers, cai..........etc
modifications: http://www.camaro5.com/forums/showthread.php?t=332717
h018871 is offline   Reply With Quote
Old 12-20-2013, 08:40 PM   #14
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
Originally Posted by h018871 View Post
One more comment:
easier(way) to replace tire/wheel
Black magic woman, don't turn your back on me baby.
SS Blinder is offline   Reply With Quote
