Old 07-09-2013, 03:48 PM   #1
murdered
Drives: 2012 2SS 45th Ann. Edition
Question Driving with only 4 lug nuts?
Yesterday on my way home from work one of my lug nuts came off on the highway. Sound weird knocking turned out to be 3 of the other lug nuts being loose and allowing the wheel to get out of whack. When I got it home (2 miles later) I jacked it up and tightened all of the nuts, on all of the other wheels too, with a 3' breaker bar.
My rear passenger wheel only has 4 lug nuts, will that be enough to drive it to the dealership and buy a replacement? Should I have them look at the wheel/axle from going ~50mph on the highway for 2 miles as I made it home?
2012 2SS 45th Anniversary Edition
murdered is offline   Reply With Quote
Old 07-09-2013, 03:50 PM   #2
buckeyemike
buckeyemike's Avatar
Drives: 2012 Camaro LS
Yes, have them look at it for sure. How far away is your dealer? My WRX had loose lugs and it messed up my axle and I needed to replace parts of it.
Be wary driving it there, perhaps splurge on the tow just to be safest.
buckeyemike is offline   Reply With Quote
Old 07-09-2013, 03:55 PM   #3
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: 2011 2SS L99 SGM 2013 2SSRS LS3 BRM
You will need to make sure the holes in your rim are not elongated, if they are your rim is toast.
cadyshac is offline   Reply With Quote
Old 07-09-2013, 03:56 PM   #4
Cheveey57
Cheveey57's Avatar
Drives: 2010 Camaro 2LT RS
No problem if the 4 are tight. ( I made it home with only 1 lug years ago in a 73 chevelle. Limped home slow but she made it.)
If you're not living on the edge, you're taking up too much space.
Cheveey57 is offline   Reply With Quote
Old 07-09-2013, 04:09 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
So why didn't you take 1 lug off each of the three others, put on the missing wheel and drive home normal ?
Old 07-09-2013, 04:38 PM   #6
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
Hindsight is 20/20 haha
SNSSTR is offline   Reply With Quote
Old 07-09-2013, 04:57 PM   #7
SmokiNstripes6913
Drives: 2013 Camaro 1LS
Im surprised there is no vibration. Why are you missing so many nuts lol.
SmokiNstripes6913 is offline   Reply With Quote
Old 07-09-2013, 06:25 PM   #8
bluBlud
bluBlud's Avatar
Drives: 2013 2SS/RS/1LE
Originally Posted by Comrando View Post
Take it easy and you should be okay.
May have messed up the wheel and/or lugs.
Who left them loose? 140 lb/ft.
140?!? I just swapped my OEM lugs with Gorilla lockers and the owners manual says 110. The old ones came off between 90 & 100.
bluBlud is offline   Reply With Quote
Old 07-09-2013, 06:38 PM   #9
ToolFan66
ToolFan66's Avatar
Drives: 2011 2SS 6.2L W/RS package
LOL!! I was thinking the same thing, not sure I would chance 1 lug nut..
KooKs LT Headers, Borla S-Type cat back, RotoFab CAI, Bo White PTB, RMCR tune...
ToolFan66 is offline   Reply With Quote
